Old 07-08-2010, 05:54 PM   #1
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Airstream Tire Protectors
I've seen a number of Airstreams with tire protectors that clip to snaps on the side of the trailer above the wheel well. They are the same color as the awnings and appear to be made of the same material. Can anyone tell me the source - Airstream? ZipDee? - and if they are still available. Never seem to remember to ask about these when I'm at Jackson Center.
Al - K4GLU is offline   Reply With Quote
Old 07-08-2010, 06:27 PM   #2
_
the fabric wheel well skirts were popular 20+ years ago...
and a/s occasionally had left over sets available for many years.
i saw some for a triple in the store 3 years ago.
but suspect they are mostly gone now and would be blue striped fabric.
yes u should still be able order them, either from j/c z/d.
the 'snap' heads (caps) are pressed into the fabric while the snap studs...
are SCREWED into the a/s skin...
yes that's correct.
_______
they do sorta dress up the units when parked but i suspect they do VERY LITTLE protecting the tires from UV...
besides the newest rv tires have MORE uv blocker stuff and should easily last 4-7 years without covers.
if in az a SHEET of ply or some real blocker might be useful...
but the skirts are cool, and expensive.
cheers
2air'
Old 07-08-2010, 06:29 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have the snaps in my trailer. Also on the inside windows. I have some fabric covers with some sought of foil in them for the inside windows. Help keep the heat in and cold out. or vise versa. I would think you would have to make them but you never know.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-08-2010, 07:53 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I have the snaps on each wheel well but the covers are long gone. I got a set of 4 canvas type covers from Harbor Freight for about 9 bucks, i think it was . They work just fine. I have pulled the wires that hold em on the wheels and MaryLou has washed em once.
Works for us.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-08-2010, 09:04 PM   #5
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I have them but they were purchased 20 years ago. I believe Zip Dee carried them. The fabric matches the awnings exactly. They look real sharp when the wind isn't blowing too hard. They do have grommets at the bottom as well for tie downs I suppose..
4RXLA is offline   Reply With Quote
Old 07-09-2010, 07:47 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Out of Doors Mart carries them as a special order item. ZipDee 29x74in Tandem Tire Shades 1TSO20 [1TSO20] - $195.95 : ODMRV , Out-of-Doors Mart
You could go to Joann's and buy Sunbrella - a punch and snap kit and roll your own for a lot less money.
sunbrella*: Shop | Joann.com
Add some lead tape strip weight to your bottom seam to help hold them in place.
Wapsi Fly Inc. - ZONKER LEAD TAPE - The Trout Shop
We also use this on the tires at least twice a year.
303 Products, Inc.: 303 Aerospace Protectant
Old 07-09-2010, 07:53 PM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Wheel covers
I am making my own from silver fiberglass based material that is used by insulators to cover high temp piping and heater tanks. It looks good and is almost a perfect blend with the trailer panels. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Segment protectors b8sfamily Rock Guards, Segment & Window Protectors 23 07-22-2016 03:53 PM
Surge Protectors and Such.... luckydc Electrical - Systems, Generators, Batteries & Solar 26 08-17-2010 12:08 AM
SS Frame Protectors - 2007 Classic Bluto 2006 - 2010 Classic (all lengths) 3 05-06-2010 06:25 PM
Basecamp Segment Protectors? Friday Rock Guards, Segment & Window Protectors 0 04-30-2009 03:19 PM
RV Surge Protectors Tin Hut Electrical - Systems, Generators, Batteries & Solar 4 06-09-2004 05:37 PM
