Go Back   Airstream Forums > Airstream Community Forums > Global 'streaming > Shipping & Export/Import
Old 07-11-2008, 10:40 AM   #1
Profile:  1986 32' Excella
vledder , drenthe
Urgent help needed baltimore
I bought a Tow Vehichle for the AS a chevy C30
I had it shipped to Baltimore for transport to the netherlands.
Now it is not loaded on board because it did not start.
The battery is brand new so likely starter motor is gone.
I need a mechanic to take a look at it @ the port.
The only other option for me is to fly to the USA and fix it myself.
I hope that a member in Baltimore can help me with this problem.
Remco r van Lent
remcolent is offline   Reply With Quote
Old 07-11-2008, 11:12 AM   #2
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Any chance you belong to AAA?
Would it be possible to have a towing/repair company take a look at it?
How about a place that services/repairs commercial trucks? I've seen these kinds of places doing roadside repairs.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 07-11-2008, 11:18 AM   #3
vledder , drenthe
No AAA
Problem is that I'm in the Netherlands and the truck is in Baltimore USA.
Remco
Old 07-11-2008, 03:14 PM   #4
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
My first guess is if it made it to Md. someone just left a light on and killed the battery.
Hopefully someone in the Baltimore area will step up and take a look.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-11-2008, 03:31 PM   #5
hampstead38's Avatar
Profile:  1967 26' Overlander
Upperco , Maryland
I live in Maryland, north of Baltimore. I'm a "shadetree" mechanic, not a professional mechanic. If this is a situation where we're talking about jump starting, I could run down to the port (with ample directions) with a set of cables and my good luck charm. If the problem is more complex (like dropping in a new starter), I could make some inquiries locallly and see if I could find a mechanic willing to go down and take a look at the truck. How much time do you have to get this problem fixed? Is is possible to have the vehicle towed onto the ship or must it be able to move under its own power?
Ken
hampstead38 is online now   Reply With Quote
Old 07-11-2008, 05:28 PM   #6
vledder , drenthe
ken
vehicle must run on its own power.
When it was brought to the port by the trukking compagny it would not start .
driver had to tap starter moter and he did put in a new battery.
most likely the starter motor is gone And there seems to be a current leak that drains the batery.
This could either be from the startermotor or from the alternator.
so to be sure it should be best to disconect the terminals on the alternator.
Battery is brand new no need for new one.
new starter motor is not hard to put in Its a C30 chevy with a 454.
thanks
remco
Old 07-11-2008, 11:00 PM   #7
Upperco , Maryland
Remco,
I just sent a PM with my number. It's getting close to midnight here but I trust we'll talk tomorrow.
If tapping on the starter made a difference, my initial suspicion would be a loose and/or bad cable rather than a failed starter. As for replacing starters, the last one I did was on my '52 Chevy truck. There's a little difference between the straight 6 216 and the big block 454... having room to work comes immediately to mind. Of course, the real problem is that we're a couple of guys talking about an engine that neither you nor I have seen in person. If it's not the starter, it could be any number of things. If the simple "check the connections and jump start" approach doesn't work, your best bet is to have a professional mechanic to the diagnosis.
The port is in the Dundalk area. I'll pull a list of auto mechanics/service garages nearby and email them to you so you can call them directly... that is if my lucky charm doesn't work. You have a PM with the details on my contact information.
Oh, by the way, let me know what the hard deadline is for getting the C30 onboard. If it's tomorrow, I'm going to put on the Mission Impossible soundtrack. That was my attempt at humor, Remco. I'm going to get some sleep and we'll work on this dilemma tomorrow.
Ken
Old 07-12-2008, 07:15 AM   #8
Upperco , Maryland
For those of you following our little drama, Remco and I are exchanging information. Oh, and in a truly odd twist, Remco bought the truck via Ebay from a seller in Libby, Montana---my hometown. What are the odds of that, I wonder. Cross your fingers, folks, and let's hope this long distance truck problem has a happy ending.
Old 07-12-2008, 08:31 AM   #9
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
tapping the starter often indicates worn starter motor brushes. if it gets started and a drain cannot be found, the battery should be disconnected for shipping. often lights are left on when checking for a dead battery and not noticed, especially in the daytime.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 07-12-2008, 08:53 AM   #10
AirstreamGypsy's Avatar
Profile:  1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
Hampstead38,
How truly AirForums of you! It constantly amazes me how wonderful people can be. Good luck with your mission, I'll be blaring the Mission Impossible theme song for you.
AirstreamGypsy
___________
AIR # 11128 WBCCI # 1818 - VAC
Charter Member FCU
CP
(Courtesy Parking)Wi-Fi
http://www.sdgraphics.net/myearthship/
AirstreamGypsy is offline   Reply With Quote
Old 07-12-2008, 11:12 AM   #11
Upperco , Maryland
Well, thanks, but before anyone gets too excited, let's see if I make things better rather than worse.
Here's a little update. The port is closed today so I'll have to wait for the coming week to head down. I called my folks in Libby. My father knows the seller and he thinks he remembers the truck, a red 1979 Chevy C30 "dually." (Like I said, Libby is a small town). As fate would have it, my father had a brown Chevy crew cab of about the same vintage that I managed to tear the door off. We were loading hay, my brother jumped out and left the passenger door open while I was backing into a hay barn. It's a mistake a person only makes once.
Back to the seller, the guy has taken and sold scrap metal for my father. Of course, being a small town, he knows the "scoop" on everyone. I'm not going to tell tales out of school, but based on what I heard, I have my fingers crossed for Remco that the truck is what he expected and that the starting problem is not major. I expect that between the purchase, hauling it to Baltimore and putting it on a ship to the Netherlands, he has some money in the TV already.
I'll keep posting updates as our story continues.
Old 07-12-2008, 12:36 PM   #12
Slackdaddy
Ike T's Avatar
Profile:  1976 Argosy 24
Marietta , Georgia
I have to ask.. are you referring to you or your brother?
This is a mighty fine thing you are doing.
Tim
1976 24' Argosy
1973 International Travelall 1010 -- For Sale
1973 International Travelette 1210 4x4 'Bernard' 164" WB
Upcoming rallies: Can Opener
Ike T is offline   Reply With Quote
Old 07-12-2008, 12:54 PM   #13
Airstream 250 MH
Boom Sounds's Avatar
Profile:  London , UK
The exact same thing happened to me shipping out of Galveston to Zeebruge last month. Sometimes, this is a scam by the port staff who subsequently offer to find a "local mechanic" to sort out the problem. They offered me a mechanic, but luckily I had a Good Sam policy and when the mechanic when down to the port it started first time. If you really do have a flat, it is more likely to be something left on or a short rather than an alternator short. Sounds like Hampstead38 is your best bet but if you both get stuck you could take out an AAA policy from his address and call them out. You also need to consider the landing and how it will be treated if it comes off the boat with a flat. Are you picking up in Zeebruge or Rotterdam? Onward travel may be an issue so check your terms and conditions.
Good luck - I am watching with interest and wish you all good luck.
Boom Sounds is offline   Reply With Quote
Old 07-12-2008, 09:35 PM   #14
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Thumbs up Un-believable
It's a small world after all....Airstream at least.
38..you-da man.
This is exactly why we all spend so much time here
Really hope all works out well.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
need TV shipped from montana to baltimore remcolent Shipping & Export/Import 2 05-02-2008 07:02 PM
Moving an AS from Rhode Island to Baltimore neillop Shipping & Export/Import 6 06-22-2007 11:27 AM
New member in Baltimore area jfcoll Member Introductions 4 06-13-2007 10:11 PM
New Jersey to Baltimore - shipping Moonstruck Shipping & Export/Import 5 03-29-2007 05:03 AM
Urgent assistance needed for Sad UK Owners UK-Airstream Our Community 13 11-23-2005 05:52 PM
