Go Back   Airstream Forums > Airstream Community Forums > Global 'streaming > Local Regs & Licensing
Prev Previous Post   Next Post Next
Old 07-27-2008, 02:38 PM   #22
Commercial Vendor
Moonstruck's Avatar
Profile:  1986 31' Sovereign
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Hello Guys,
I realise I'm a bit late to this thread, but here goes. I imported my 31' Sovereign from the US in Dec '06. I fitted a "big ole" toroidial transformer in it to run the AC, Dometic FF, Microwave and Charger. The "yellow boxes" will provide a 110v supply but they come with a warning not to use for an extended period of time. The system runs from a 240v supply through breakers that also supply a 240v ring installed separately from the 110v system. It's VERY reliable and all apps work perfectly. Mail me if you'd like any advice.
Marc
NB. I have found that, whilst they look identical, US gas fittings have a slightly different profile and you will get a leak if you hook up to uk tanks!
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
