Go Back   Airstream Forums > Airstream Community Forums > Global 'streaming > Local Regs & Licensing
Old 02-15-2008, 04:26 PM   #1
'Bud'
safari's Avatar
Profile:  1998 25' Safari
AUSTIN , Texas
trailer/tow vehicle axle weight regs
in our camping job where we are gate attendants, we keep hearing from our campers that when they travel from state to state, when their tow vehichle is pulling their rv, in some states, you could be pulled over by law enforcement to have the weight of your axles of your tow vehichle as well as your rv checked to see if they are in compliance with state laws. If found not to be, they can take your rv and tow vehichle and fine you up to 10,000.00.
In addition, we were told that if you go to a certain trucking company which regulates this and have your tow vehichle and rv weighed and get a copy of this info, you can show this, then have no problems, with law enforcement per what the campers tell us.
this is what we have been told and we have never heard of this and would like to check the validity of it.
safari is offline   Reply With Quote
Old 02-15-2008, 06:37 PM   #2
Profile:  1975 29' Ambassador
Reno , Nevada
You see this sort of fear on RV discussion boards every now and then. Any LEO harassing an RV driver about weights is probably way out of line.
I have yet to see any state law that makes the vehicle weight ratings for RV's a legal standard. I have not seen any insurance impact either. There have been allegations about it being a factor in assigning blame for crashes but I have seen no substance there either as crash investigations seldom weigh the debris except in commercial situations.
The only caveat I have seen is a case of severe overloading to the point that the vehicle can barely get down the road - and that really has to get extreme to cause any notice in my experience.
The state's primary involvement with vehicle weigts is for commercial traffic and primarily as a tax on commerce.
Old 02-15-2008, 06:43 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
I have not see any state weight an RV but I had heard the BC does and may if you are overweight tow you to there boarder. Even if the states do start this a doubt the fine will approach 10,000. Each state has an overweight fine schedule for trucks and I would assume if inforced that would be the rate structure. It s all about money.
The upcoming problem is that insurance companies are reportly consider weighing a trailer that are involved in an accident for over weight. Over weight may not only be the weight of the trailer but also if the trailer exceeds the rated load of the TV.
It is a good idea from a shear safty consideration to weigh your trailer. Those shoes under the bed and cans of beans do add up.
Another consideration is the fact that RV makers are realy cutting back on the capacity a given trailer can hold. Last year Airstream sold a trailer in the US that had a 40 lb. capacity. That same trailer sold in Canada would carry 400 lbs.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Sovereign weight and Preferred tow vehicle JLD 1978 Sovereign 3 03-05-2008 02:52 PM
Tow Vehicle Question-for a 34 ft, 3 axle Excella dmreilly10000 Towing, Tow Vehicles & Hitches 22 04-21-2007 02:50 PM
Calculating Tow Vehicle and Trailer Weight - Woes campadk Towing, Tow Vehicles & Hitches 18 09-12-2006 08:58 PM
Tow vehicle/Trailer match Darrell Root 2004 International CCD 7 07-31-2006 11:20 PM
Do I need sway control, weight bars and a good tow vehicle? Silvertwinkie Hitches 28 07-19-2004 08:42 AM
