Old 09-10-2019, 05:31 PM   #1
Alice&Billis's Avatar
2006 25' Safari
Tyler , Texas
Wire Loom at front of trailer
I have removed the top and side covers that runs the width of the trailer. Has anyone ever modified the cover to allow for couch placement or other projects?
I call it a loom but itís actually more of a birds nest of wires and several coils of wire secured with tie wraps that are not connected to anything on that end.
Thoughts or ideas are welcome.
Alice&Billis is offline   Reply With Quote
Old 09-10-2019, 06:04 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I am in the middle of that right now. I sold my original sofa and am replacing it with a 70" double reclining loveseat with a console in the middle. You are being generous when you call it a wire loom. My name for it is not repeatable in mixed company.
You can see mine here:
http://www.airforums.com/forums/f38/...-a-195228.html
I have to relocate the DC distribution panel and converter assembly that was on the roadside end of my sofa so it is closer to the wall. I may have to disconnect all the 12V load wires from the breaker panel to do that, but maybe not. I haven't gotten far enough into it yet. I do know that the main battery negative cables are too short. I'll probably have to replace them as I don't want to splice in 3' more wire.
I'm going to take a 12 volt power supply so I can feed 12V to the thermostat and run the air conditioner but I'll disconnect the batteries and the converter so all the other 12V circuits will be dead. There is no shore power AC in that area, only 12V DC so my plan should keep me from getting electrocuted or setting the trailer on fire. As you can see in the second picture, I also have battery boxes to deal with. The base of my loveseat will be 11" off of the wall so I'm probably just going to rebuild what is there so that it isn't such a kluge. In fairness to Airstream, the flooring had been replaced when I bought the trailer so whoever did that probably did the shoddy job of installing the cover. The only vertical support for the edge of the top cover was a couple of 3/8" square sticks that were screwed into the top and the front cover. They were screwed to the floor with a couple of angle brackets. I'm going to put down a furring strip all the way across the floor and screw the front cover into that.
At least that is my plan until I get into it. They say a battle plan never survives first contact with the enemy.
By the way, the unterminated coils of wire are probably the solar panel wiring.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-10-2019, 10:56 PM   #3
2006 25' Safari
Tyler , Texas
Wire Loom!!!
Thanks for the reply...yes I was being generous with a name for it and surprised at how shabby the installation of all those wires and gadgets were done on the assembly line. While I guess it needs to be shielded with something, it just doesn't need to be so intrusive into the room. We pulled the original couch out years ago, I found some used club chairs for comfortable seating and then on vacation in July we stopped by Bradd and Hall in Elkhart Indiana and ordered a Lambright wall away recliner couch which is now installed. You have quite a project! The only reason I removed the shield was to allow the couch to go back against the wall a few inches. I guess I'll just make some cuts on the table saw to reduce it a bit, reinstall and protect what's there.
UV resistant split loom source? SSquared Generators & Solar Power 2 08-28-2018 10:58 AM
Tail, Marker lights, wire loom? 1958 Traveler cuyeda Lights - Interior & Exterior 6 08-17-2012 12:17 AM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
