Old 10-05-2005, 08:59 PM   #29
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Found this today for those interested in more pics of a 23 footer:
http://www.rvtrader.com/rvdetail191272.htm
Old 10-05-2005, 11:02 PM   #30
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
23 footer
Did all y'all notice that the propane cover was moved forward on the hitch frame. Looks like the battery would have to be behind it. I wonder why they did that? Is it only on this model or is it going to be this way on all '06's?
Tin Lizzie
Old 10-05-2005, 11:23 PM   #31
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Maybe
they moved them forward so that it's easier to hookup weight distrubution saddles on the A frame? The propane cover might have gotten into the way before. It also looks llike it comes with two batteries - there might have not been room forward of the bottles for this...but I think the bottles are just as wide, so I vote for the w/d setup as the answer.
Marc
Old 10-06-2005, 06:23 AM   #32
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Y'know... this is really pretty cool! My very first Airstream was a '70 Safari Special 23'... 3750lbs dry... with almost an identical floorplan! It wasn't short enough to be a "small" trailer, and wasn't long enough to be practical... but it suited our traveling needs well for a bunch of years... AND I bought it for $2k in 1987!
Old 10-06-2005, 07:46 AM   #33
Aluminut
2004 25' Safari
. , Illinois
Looking closer at the photos, it seems that the propane tanks our 2004 Safari SS are in the same location as it is on this unit.
....and good luck paying $2k for this unit....even ten years from now....though I'll be honest, dealers today having dealt with 3 aren't wheeling and dealing like they were for the 2004 we bought. I would have thought differently given the gas issues and such....thought they'd snap at a sure sale, but alas, looks for now, we're gonna stick with our 25' as is, unless the deals get better....none of the dealers are offering ANY amount off retail with a trade on a special order unit and are quoting me NADA values when clearly you see the dealers advertising used units well above the numbers that are listed in the NADA guides. In 2004 I got what we paid for our 2003 Bambi and Sherry RV offered approx 10-12% off retail on our special order unit.....not this time around under similar circumstances and a better decked out coach to trade.
Old 10-11-2005, 11:22 AM   #34
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
The Dinette Floor Plan 23' 2006 Safari has just arrived at Colonial Airstream if anyone is interested in seeing what one looks like, compared to the L-Lougne and Sofa Models seen earlier.
http://www.colonialairstream.com/newinventory/7883.html
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 10-11-2005, 11:28 AM   #35
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Tin Lizzie
From the pictures it looks like its in the same place as before. Both my 2001 Safari and my 2004 Classic have the gas bottles in the same exact location. In the 2001 Safari there was a battery box behind the tanks. In the 2004 Classic its an empty storage box although on the new Classics that box seems to contain the components for the disc brake system.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-11-2005, 07:04 PM   #36
1968 17' Caravel
Images: 79
I have seen the Bottle Cover Relocated on the 06 22' CCD’s and other 23' Safari’s. I think it makes turning off LP tanks a lot easier with the Lift up Hinged Lid found on the other Airstream trailers. It also appears NOT to interfere with the weight distribution kit or sway control that will have to be installed. In the past one would have to cut or modify the (22’ Safari & CCD) bottle cover to install the proper hitch work.
Pic 2006 International CCD 22'
Old 10-11-2005, 07:26 PM   #37
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
FYI, Speaking of bottle covers...
While I was doing a cursory inspection of my Bambi yesterday, I removed the aluminum bottle cover in order to follow the path of the trailer wiring, and found that there were marks on the inside that indicated the tanks had been rubbing up against it in several palces. I believe if I left it as it was, it would have eventually abraded through the cover. I readjusted the tanks, which were apparently installed off-center by Airstream, covered the contact points with some soft velcro pads, and then repositioned the cover so it was as far away from the tanks as possible. I think I may have averted some future problems.
SilverRanger is offline   Reply With Quote
Old 03-03-2006, 08:20 PM   #38
LuminumTraila's Avatar
2006 19' Safari SE
NW of Boston , Massachusetts
"L" Sofa
Does the "L" Sofa in the Safari 23' make up into a bed like the older gauchos that look similar?
Doug & Jamie, AIR #650
LuminumTraila is offline   Reply With Quote
Old 03-03-2006, 09:08 PM   #39
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
I see some changes on the other models too. Doorbell on the Classic and decorative vinyl entrance and bath mat on the 25' Safari.
Caroljb
photography
wheel interested is offline   Reply With Quote
« - | Top | dumb question »
Cool Airstream Model Mr Jody Hudson Our Community 12 03-19-2006 09:19 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum Admin, News and Member Account Info 2 10-15-2002 07:38 PM
Purchase of 73 safari april Our Community 11 09-01-2002 02:33 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 06:49 PM
