Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2005 - 2010 Safari
Old 09-05-2014, 08:42 PM   #1
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Info Please
Has anyone with a 23 foot AS Safari removed the microwave (located above the refrig) and installed a larger refrigerator? I'd like to have a larger refrig since we really haven't use the microwave but a couple of time since 2006. Wonder if Dometic even makes a unit that would fit this space width wise.
tsunami is offline   Reply With Quote
Old 09-05-2014, 08:54 PM   #2
1974 Argosy 20
Kooskia , Idaho
Does your 23' Safari have a roof vent for the refrigerator, or only an upper side vent?
If it has no roof vent you will not be able to put a taller refrigerator in even w/o the microwave. If it has a roof vent, not a side vent, you might be able to put a larger (taller) one in, it will take some measurements. You will need to consider the slope of the side wall especially to see if there is enough depth available at the top.
I put a taller refrigerator in my '74 Argosy by removing the lower stand the old one sat on, and raising the countertop over the refrigerator area. It worked out very well and I am much happier with the increased refrigerator space. All the old Argosy's had a roof vent. It is only some of the more recent smaller AS units which have the side vent and fan system which are a real problem to work with.
Old 09-05-2014, 09:33 PM   #3
tsunami's Avatar
Images: 20
Yes, it's got the upper and lower side vents with the 12 volt fan for ventilation.
Old 09-05-2014, 09:43 PM   #4
1974 Argosy 20
Kooskia , Idaho
you are out of luck then. A taller refrigerator will not vent with the upper side vent system and fan. A roof vent would be needed.
1963 HENSLEE Aluminum Travel Trailer.. Info, please??? flamingo-kid1 Vintage Kin 14 02-11-2015 11:45 AM
wow info overload/Classic info wanted SterlingSRCH Classic Motorhomes 7 02-15-2013 08:41 AM
Towing Info Please, on our Honda PIRATES Tow Vehicles 18 05-15-2006 08:47 PM
Mystery trailer - info please Janet H Vintage Kin 13 08-19-2004 08:15 AM
Info on 31'/72 Inter. Sovereign please jwaldin Our Community 1 01-10-2003 06:56 PM
