Old 03-28-2014, 02:35 PM   #1
eugene , Oregon
Wiring vent fan
I just removed a broken roof vent from our 23' safari. It was the rear vent.
I'd like to install a new vent with a fan but there is no electrical at this site.
What is the best way to either run a wire from a light or run a new circuit?
I am a electrical novice.
cyafishin is offline   Reply With Quote
Old 07-15-2014, 06:23 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Good question, Hopefully I will have this problem soon. Any suggestions?
MICHAEL
Old 07-15-2014, 07:08 PM   #3
dznf0g's Avatar
Oswego , Illinois
Are you sure there is no wiring there. I thought AS put the wiring in for options whether they are there or not. Was a fan an option in that location for your unit? If so, run your fingers way back under the insulation when the old vent is out.
I know my 07 had all the wiring for the audio upgrade and TV, which was not ordered by PO.
A call to Randy McNeely at AS might help.
-Rich-
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? pejokerst Airstream Classifieds 0 02-19-2014 08:45 AM
wiring for vent fan? paul55 Electrical - Systems, Generators, Batteries & Solar 0 03-12-2012 11:02 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Vent Fan Wiring Ag'71 Electrical - Systems, Generators, Batteries & Solar 2 09-30-2009 08:19 AM
vent fan wiring joel Electrical - Systems, Generators, Batteries & Solar 3 07-06-2005 09:10 PM
