Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2005 - 2010 Safari
Old 02-01-2011, 10:36 PM   #61
Westfalia's Avatar
Some Place with a German Name , Texas
Images: 35
Send a message via AIM to Westfalia
Here are some shots of the removed panel. Pardon the bedroom mess.
ID:	121205   Click image for larger version
Westfalia is offline   Reply With Quote
Old 02-02-2011, 07:26 AM   #62
RichHog's Avatar
1972 23' Safari
Houston , Texas
Chris would you say that the wall panel is about 1/2" thick? I had to glue the panel shut after the initial road trip when I bought it, it was coming loose at the shower door edge. I may try to use short screws and glue the mount to the panel. If that doesn't work then will take the panel off and use bolts. Thanks for the pics!
RichHog is offline   Reply With Quote
Old 02-02-2011, 07:47 AM   #63
Westfalia's Avatar
Images: 35
Yes, probably 1/2" inch. I'd say maybe 1/2 inch of add'l dead space between the wall and pan, probably less.
Old 02-02-2011, 08:00 AM   #64
RichHog's Avatar
1972 23' Safari
Houston , Texas
ok thanks for the pics, these new flat screens are pretty light weight and thin for trailer use. I'll post photos of the finished work.
Old 02-14-2011, 08:09 PM   #65
RichHog's Avatar
1972 23' Safari
Houston , Texas
Cat Scale Weight of 25 SafariSE
Took it to the Cat Scale to weigh her and came out to 5260 lbs. Some water in tank, propane mostly full and basic stuff loaded, towels bedding, no food. That was less than the 6500 I expected. Anybody else with the 25 fBSE?
Old 02-14-2011, 08:22 PM   #66
_
d u n clude da tung?
cheers
2air'
Old 02-14-2011, 09:47 PM   #67
Splitrock's Avatar
Sioux Falls , South Dakota
cheers
2air'
Sounds like the Chinese three stooges . . .
SlingSheetHi, WhoFlungDung, and OneHungLo
Old 02-15-2011, 08:19 AM   #68
RichHog's Avatar
1972 23' Safari
Houston , Texas
Aaaaah so.. Trailer was still connected to TV so that could skew results slightly.
Old 04-06-2011, 10:11 PM   #69
RichHog's Avatar
1972 23' Safari
Houston , Texas
Anyone know the model number of the Duotherm AC Heat Pump? Went through the manuals no luck but the sales sheet says it's 11,000 BTU which seems strange as thought it was 13,500. First time to try out the AC and she blows hot so trying to find part and service manual.
Sylvia :: 2006 Airstream Safari LS idmtman Airstream Registry Discussions 0 08-19-2011 08:31 AM
3291 :: 2006 Airstream Safari LS FB utah bob Airstream Registry Discussions 0 08-19-2011 08:31 AM
