Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2006 Safari SE
Old 07-02-2007, 05:46 AM   #1
jzelle's Avatar
Profile:  2006 28' Safari SE
Orleans , Ontario, CANADA
Hanging pictures
How do you hang pictures on that nice shiny SE interior without damaging the surface?.
I am considering applying velcro patches but am worried that if I remove them later that the clearcoat might be damaged.
Has anyone here mounted any pictures in their Safari SE?.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 07-02-2007, 06:18 AM   #2
beckybillrae's Avatar
Profile:  1986 31' Sovereign
Schererville , Indiana
The coach I just bought had sticky tack in it to hold pictures up. It wiped off the walls & didn't leave any marks.
Becky
beckybillrae is offline   Reply With Quote
Old 07-02-2007, 06:20 AM   #3
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
John, not to worry, there is no clear-coat on the interior skins. Hang away!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 07-02-2007, 08:58 AM   #4
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
I think here must be a coating on the interior walls or otherwise the walls would produce black smudges when you wiped them.
Also, if there were no coating the Velcro adhesive might produce a chemical reaction with the raw aluminum.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 07-02-2007, 09:19 AM   #5
2airishuman's Avatar
Profile:
no clearcoat on the interior skin?
where'd that info come from?
the exposed interior skin on newer units....
is the SAME alcoa clearcoated aluminum that is used on the exterior...
corrosion and all!
for hanging without holes,
try the 'command' products from 3m...
Command Home
i've had things attached in the shower, on the woodwork and on the clearcoat aluminum...
for 2 years.
no loosening, and no blemishes to the surfaces...
ANY adhesive product will break loose eventually
given time and heat inside the unit.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 07-02-2007, 10:48 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
I'll pipe in as an SE owner and fully agree with 2air'. The interior skin has the same gloss and feel as the clearcoated exterior. Everything I've heard and read is that it's the same skin used on the outside. I believe you'd get scratches from road vibration if you mount a hard object (eg, picture frame) that actually contacts the inner skin. If you're set on owning your Airstream until both of you are old and tired, you might as well drill a hole and come up with a mount you can pop rivet to the skin. I wouldn't be real impressed if looking at a used unit like that but other issues would be much more important.
Clay-like tacky stuff eventually leaves an oil residue on posters when I've used it. There's a 3M double-sided foam tape for posters that works too well or not at all. Never use solvents or abrasives anywhere on clearcoat. Try a bit of veggie oil on a fingertip if trying to remove something from clearcoat.
Old 07-02-2007, 11:03 AM   #7
1960 24' Tradewind
Yes, there is a thin anti-ox coating on the inside from the aluminum supplier but not "Clear Coat" as sprayed on the exterior skins once assembled. Sorry for the confusion!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
Old 07-02-2007, 04:04 PM   #8
jzelle's Avatar
I believe 2air' is correct as to the clearcoat on the exterior. As far as the exterior is concerned it is my impression that on all late model trailers the clearcoat comes with the raw material from Alcoa , there is no clearcoat aplied after assembly.
John
Old 07-02-2007, 04:07 PM   #9
jzelle's Avatar
Thanks,2air'
I'll try the 3M Command product. It seems to be a good solution as I certainly will not drill holes in the skin.
John
Old 07-02-2007, 08:10 PM   #10
Marti's Avatar
Profile:
Images: 20
I hung everything with Velcro... seems to stay ... no problems falling off when you move your trailer....
Marti is offline   Reply With Quote
Old 01-26-2008, 11:24 PM   #11
1Bombshell's Avatar
Ventura , California
Hanging Pictures on SE walls
Velcro with the sticky stuff! Works great.
~Rob~
1Bombshell is offline   Reply With Quote
Old 01-26-2008, 11:28 PM   #12
millvalleyca's Avatar
Profile:  2008 27' International CCD FB
Mill Valley , California
3M Command works great! It's very strong and comes off clean.
millvalleyca is offline   Reply With Quote
Pingbacks are On
35 new pictures posted of 58 Traveler restoration williamhenshall 1958 Traveler 12 09-03-2002 10:08 PM
Deletion of Sale Post and Pictures winner Forum How-To's & Support 7 05-04-2002 06:15 PM
Pictures loaded eraffety Airstream Motorhome Forums 18 04-08-2002 10:32 AM
How to include multiple pictures in a post! PeterH-79MH Forum How-To's & Support 1 02-23-2002 10:36 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
