Old 03-13-2011, 02:54 PM   #1
idmtman's Avatar
Worley , Idaho
Digital to Analog Converter... suggestions
We have the WEGA Sony LCD television in our AS. The TV is analog (can't get any reception plus looked it up on Sony website to verify it is analog only). It works fine so I'd rather not replace it. Any recommendations for a converter box location and recommended product? Thanks for any help.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 03-13-2011, 03:31 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We've got a converter for the TV in the camping cabin. It was just the basic model from WallyWorld, and it works well. It is also quite small, so you might be able to hide it in a small corner.
(We no longer have it in the cabin, though. Some slob swiped the remote for the TV, and, not noticing, I unplugged both TV and converter. Now I can turn on the TV manually, but can't turn the RV to the required channel 3 without the remote!)
Lynn
WBCCI 21043
Old 03-13-2011, 03:57 PM   #3
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
Heres one that is pretty cheap: CompUSA.com | 1080D | AccessHD DTA-1080D Digital Converter Box
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 04-06-2011, 09:59 PM   #4
RichHog's Avatar
1972 23' Safari
Houston , Texas
Took mine out and replaced with a 26" Vizio from Costco for $230. Figured that the convertors were $30 and wanted to add HDMI inputs for Apple TV. Plus widescreen format. The new Vizio is thinner and lighter and 1080P.
If you do replace then you'll never get the power adapter out from behind the wall. Had to cut the cable and leave it back there.
RichHog is offline   Reply With Quote
Old 04-06-2011, 10:01 PM   #5
Ottawa , ON
lynn,
Just buy one of those generic remotes for the Sony. They work fine.
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 12:17 PM
Original AS Converter Question Hummer Batteries, Univolts, Converters & Inverters 4 02-25-2011 04:22 AM
converter size lahrfarm Batteries, Univolts, Converters & Inverters 10 02-20-2011 06:52 PM
Upgrade converter? Breadbug Batteries, Univolts, Converters & Inverters 5 01-15-2011 02:08 PM
