Old 11-16-2010, 03:55 PM   #1
HCR
HCR's Avatar
Livingston , Full time traveler
Blanket UNDER mattress
As a newbie to AS, a problem every night has been that the mattress moves away from the wall. Solution is probably common knowledge among As owners, but I didn't know, until a friend suggested, that by placing a blanket under the mattress, the mattress will stop "walking" during the night.
Now all I must do is extend the plywood upon which the mattress rests to compensate for the fact that the bed design results in the mattress hanging over the edge of the frame. Can anyone tell me why that design exists? Must be a good reason that my simple mind can't figure out.
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 11-16-2010, 04:40 PM   #2
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
don't know why
We put an egg-crate foam pad under ours. It keeps them from walking around and it also adds a little additional insulation. Since we live in a cooler climate and the beds are over storage compartments. The extra insulation is good.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 11-16-2010, 04:43 PM   #3
glogeo's Avatar
1978 29' Ambassador
2006 30' Classic S/O
Pine Bluff , Arkansas
HCR, Try the "no slip" rug pads sold at Lowes....that should work for you at night but still allow you to move the matress around to make the bed
glogeo
glogeo is offline   Reply With Quote
Old 11-16-2010, 05:40 PM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I used some 6" pieces of wide Velcro at the corners of the bed pedestal. Either the fuzzy part of the hook art work will pretty well to stop the mattress walking.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 11-17-2010, 01:41 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I took a pair of web straps with plastic buckles to hold my mattress in place. I put one at the foot of my bed and the other one at the side facing the rear of my trailer. Each strap has one end screwed to the bed platform and the other end sewed to the mattress. This allows enough movement to make the bed, but doesn't allow it to move around while laying in it or while driving.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-17-2010, 09:29 AM   #6
AZ-JH's Avatar
Peoria , Arizona
OEM Mattress Replaced?
It sounds like your original RV "short" queen has been replaced with a standard size queen. Our original mattress has been replaced with a regular sized queen and we now have the same issue of the mattress hanging over the edge of frame. It doesn't bother us too much but eventually we'll extend the plywood.
Janet & Leon
2007.5 Dodge 2500 5.9L Cummins 16+ mpg towing
4CU
AZ-JH is offline   Reply With Quote
Old 11-17-2010, 11:14 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Bed platforms that are 4-5" shy of the mattress edge have been a weight saving, space expanding design 'feature' for quite some time now. Sitting on the bed or untrained owners not leaping to the middle when they get in bed causes all the trouble with the mattress walking in that direction.
I'm more inclined to increase the platform a couple inches to get around the much more annoying issue of bedding getting caught in the under-bed storage compartment doors every time I want to get out a pair of socks or examine my Wally Byam bottlecap collection one more time.
5 meter Langford Nahanni
Old 11-17-2010, 05:22 PM   #8
RichHog's Avatar
1972 23' Safari
Houston , Texas
I haven't had a problem yet with the queen bed slipping. Maybe the PO had fixed it. Good thing about buying a 4 year old new trailer is that the original issues have been fixed - I hope.
RichHog is offline   Reply With Quote
Old 11-17-2010, 07:24 PM   #9
HCR
HCR's Avatar
Rich--one would hope the problems have been fixed when buying a 4 yr. old trailer, I agree, and in my case, that's not the case. Lots of small and irriitating issues.
My trailer does NOT have a queen bed--two single beds and each has the overhang of the mattress.
Old 11-17-2010, 07:29 PM   #10
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Kind of like marriage, huh?
cclarkego is offline   Reply With Quote
Old 11-17-2010, 08:00 PM   #11
HCR
HCR's Avatar
Well, Carol, a lot of marriages go bad from a bad bed, or bad bedtimes, or something like that.
Old 11-17-2010, 08:04 PM   #12
cclarkego's Avatar
1966 24' Tradewind
Images: 8
Then there is also bad in bed......
Old 11-17-2010, 08:22 PM   #13
HCR
HCR's Avatar
I surrender, white flag and all that--can't run the risk of getting banned from this site--too many issues with the new (to me) Stream.
Old 11-17-2010, 09:47 PM   #14
Salem , Oregon
Images: 18
Hi, that's OK, just list/post them one at a time.
2005 Safari 25-B
Old 11-17-2010, 10:01 PM   #15
RichHog's Avatar
1972 23' Safari
Houston , Texas
Well I've only spent 4 nights in mine, bought it a month ago, but the bed is pretty nice. Then again I went from a 72 Tradewind with 2 single beds in it.
Old 11-17-2010, 10:17 PM   #16
Gainesville , Florida
Seems to me the matresses squish down and spread out and then hang over the edge a bit. zz
Old 11-18-2010, 05:33 AM   #17
HCR
HCR's Avatar
Took advice of Glogeo and bought a no-slip rug pad at Lowe's (2X 8 feet and the heavy duty version for about 15 bucks).
Success--mattress stayed put!
Old 11-18-2010, 09:25 AM   #18
First pointer is to fly below the radar. Repost on any oft-repeated issue. Mods are bored by such stuff and won't look in.
We all have lived with the work rule of "Don't say anything you wouldn't repeat to your mother." Now, my mom is very conservative and proper -- and she still surprises me a lot! I'd have had work problems following the rule... So far, this thread demonstrates good judgment about staying within the lines.
Old 11-18-2010, 09:43 AM   #19
glogeo's Avatar
1978 29' Ambassador
Glad that worked....connecting like this is like and encyclopedia worth of knowledge....in volume AC for airstream camping LOL...the only cost or rule is to.. at some point... "pass it on" by somehow helping another person with a problem...see ya on the road Glogeo
Old 11-18-2010, 11:22 AM   #20
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Our solution to the walking mattress is to push it back towards the wall. Takes a second.
Of course, mattresses don't move on their own and a mattress that was in place before bedtime must have moved because of some activity during the night. Perhaps it was mice struggling to get out from under the mattress, or perhaps "personal time". So, a round of applause to all senior citizens with walking mattresses!
Oh, as for my mother, I said a lot of things in front of her that she had some difficulty with, but as she got older, the loosened up and at times in her 80's outdid me. Parents never stop embarrassing you.
Gene
Futon Mattress to Replace Front? Gaucho Bed Mattress? lanajane General Interior Topics 8 05-26-2016 05:07 PM
electric blanket? janiemerle Furnaces, Heaters, Fireplaces & Air Conditioning 9 02-15-2010 06:33 AM
Is there a better mattress out there? yakman General Interior Topics 61 08-14-2009 03:41 PM
Solution for blanket hogs Happycampers Off Topic Forum 1 09-21-2007 08:05 AM
mattress bina Upholstery, Blinds, Walls & Interior Finishes 10 02-14-2007 04:44 AM
