06-12-2015, 10:10 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Red Barn Liner
Finished the Red Barn Safari.....and no rest in my soul. Meet, and follow, my new friend....the Red Barn Liner. I can use all the help and info available here.
06-12-2015, 10:59 AM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Inside pictures, please.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
06-12-2015, 12:06 PM
1953 32' Liner
1955 22' Safari
Valley View
inside as found
for you Bruce....you have "been there" before. Lots of work as this is a park model.
06-12-2015, 02:58 PM
1997 30' Excella
San Antonio
It is pretty though. The ones I drag home look much worse than that!
Bruce
06-12-2015, 03:10 PM
1979 23' Safari
1954 29' Liner
Orange
Melody Ranch,
What is the serial number on your Liner?
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
06-12-2015, 03:45 PM
1953 32' Liner
1955 22' Safari
Valley View
O5003 Bill. I am, and have been a fan of yours for years.
06-12-2015, 09:56 PM
1979 23' Safari
1954 29' Liner
Orange
Thanks, three earlier than mine and from Ohio also. Someday we need to meet.
Bill
06-25-2015, 08:58 AM
1953 32' Liner
1955 22' Safari
Valley View
Torflex today
Axles on the way.
06-26-2015, 08:24 AM
1953 32' Liner
1955 22' Safari
Valley View
Hornets
Something I have never encountered before.....hornets. I saw a few as I tried to get the Airstream peeped for travel home and I used my recovery kit bug spray on them. I thought I had the problem solved. Nope. A few showed up over the past week, however, as I tried to remove the belly pan for A frame replacement...HORNET all over. Work stopped now for past two days.
07-03-2015, 06:06 PM
1953 32' Liner
1955 22' Safari
Valley View
progress this week.
Thanks to Bruce Wood....I semi followed his guidance and replaced the A Frame. It needed to be extended for function....ability to fit a load control hitch and give some turning comfort zone ability.
07-12-2015, 09:37 AM
1953 32' Liner
1955 22' Safari
Valley View
Today the value went DOWN
As I have tried to say many time....the minute you start the deconstruct of that "excellent condition" Airstream you got from Ebay or Craigslist, the value goes straight DOWN. You have also started down a very long and EXPENSIVE road. I have done this before. but it still bothers me.
07-12-2015, 02:42 PM
1953 32' Liner
1955 22' Safari
Valley View
Don't do this
When you rebuild your Airstream interior....don't do it this way. I found this as I deconstructed the bed area. 2 x 4 lumber is good for barn building...not Airstreams.
07-12-2015, 03:01 PM
1997 30' Excella
San Antonio
But, but, it IS sturdy!!
Bruce
07-14-2015, 03:48 PM
1953 32' Liner
1955 22' Safari
Valley View
today, more inside
Having trouble removing the floor cabinet mount screws...the big ones. I guess slow but sure approach might work. The sink Galley cabinet base is also going hard and slow.....something is holding it in place. The bedroom are is now out. I can see the floor problem areas which will need replacing. The original Zolatone is visible now that the cabinets are removed.
07-15-2015, 09:50 AM
1953 32' Liner
1955 22' Safari
Valley View
Keep moving....or they get you
Vintage Owners will know what I mean...
07-24-2015, 09:46 PM
1953 32' Liner
1955 22' Safari
Valley View
axle swap
The belly pan has been cut out for replacement and floor inspection. The old sprung axles have been cut off and 1/4 inch angle welded to the frame the entire length go the wheel wells. Dexter 3500 lb tortion axles mounted to the reinforced angle/frame sections.
07-24-2015, 11:03 PM
1971 21' Globetrotter
Arvada
Are you welding them on?
07-25-2015, 06:40 AM
1953 32' Liner
1955 22' Safari
Valley View
Yep! After talking with Dexter and a trailer manufacturer I went this way. They even have directions and sell angle mounts...like the 1/4 in angle I used, made for the welding installation. Where the supports are in the photos I have left original sections of the axle mount/frame reinforcements and will have them extend thru the pan for use as jack points.
07-27-2015, 03:28 PM
1953 32' Liner
1955 22' Safari
Valley View
brakes and hubs
Awaiting the new tires and rims to complete the running gear.
08-01-2015, 10:20 AM
1953 32' Liner
1955 22' Safari
Valley View
trial run new axles
seem to run straight and the height is good. Belly pan is next. Interior strip out at same time.
