Go Back   Airstream Forums > Airstream Community Forums > Official Announcements
Old 04-25-2008, 05:16 PM   #1
flush riveter
bbwwjd's Avatar
Profile:  1967 24' Tradewind
kelso , Washington
What wrong with the classified function????
I have tried in vain for an hour to post an ad.And it just keeps asking me to log in,even tho' I did log in dvery time and it states that I am logged in. Please help Thanks,Len
bbwwjd is offline   Reply With Quote
Old 04-25-2008, 05:28 PM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you are using Fire Fox it is a cookie issue. If Fire Fox you have denied a secondary cookie some time in the past that allows access to that section. I have had the same problem in the past.
If this is the case go to Tools, options. privacy, exceptions and look for any Air Forum cookies that is Blocked. Remove the Blocks one by one till you find the one giving you the problem.
If you are using another browser, internet explorer, it may be the same problem. Internet Explorer has tried to copy Fire Fox to become a usefull browser and they may have set the same conditions.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 04-25-2008, 05:45 PM   #3
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
I was just able to load a test ad. When you go to the classifieds page, look in the upper right hand corner - you may have to login there.
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Ignore Function doorgunner Forum How-To's & Support 56 01-31-2008 09:56 PM
Search Function Busted 66Overlander Forum How-To's & Support 6 11-27-2007 10:09 PM
Search function? markdoane Forum How-To's & Support 6 09-14-2007 12:35 AM
univolt function mlmarch Classic Motorhomes 12 04-13-2007 02:39 PM
What is this function? bkpine Fresh Water Systems 2 08-15-2002 05:01 PM
