Old 02-27-2014, 09:29 AM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
What changed
Yesterday no adds, today adds everywhere. I have have Addblock plus enabled. I am an Irv2 supporter and I am logged in. The same as I was yesterday. So what changed overnight?
The same thing is happening on the iRv2 site.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 02-27-2014, 09:35 AM   #2
eubank's Avatar
1967 30' Sovereign
Angel Fire , New Mexico
Ah, I'm using Abine's blocker and see none of the ads, as usual. I kind of suspect that the problem might be on your end?
Anybody else seeing anything unusual?
Lynn
WBCCI 21043
Old 02-27-2014, 10:12 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Metairie , Louisiana
Using the same browser both times? I notice that when I log on using Chrome, ads are blocked, but when I log in using IE, they're not, because I hardly ever use IE anymore and never enabled adblocker on that browser. The difference is all in my computer settings, not on the Forums website. Apparently adblocker is browser-specific.
Don't know if that's what's happening with you, though. Just tossing out ideas to see if any of them stick.
WBCCI #1105
TAC LA-4
"In a perfect world, I'd be given enough time to wrap up one emergency before the next one starts." —Freefall©2013
Old 02-27-2014, 04:57 PM   #4
adonh's Avatar
1976 31' Sovereign
I use Firefox 27.0.1 and Ad Block Plus 2.5.1 that was updated today. Yesterday no adds, today adds everywhere. Whats strange is that only 2 web sides that I get adds is Air Forum and iRv2 which are both Social Knowledge run forums. I have shut down the computer, logged off and back on and still adds . Strange
Don Hardman
1976 31' Sovereign
Old 02-27-2014, 05:16 PM   #5
Let's think about what you just wrote… Ad Block Plus was updated today, and today the ads are showing up. Seems to me based on those two statements that the first place to look for a problem is in Ad Block Plus; there might be a setting that was changed due to the update, that you'll have to manually restore to the way you want it.
WBCCI #1105
TAC LA-4
Old 02-27-2014, 05:30 PM   #6
Baltimore , Maryland
I have an ad coming out soon. I hope you don't block it…
Old 02-27-2014, 06:47 PM   #7
adonh's Avatar
1976 31' Sovereign
I am now on a different computer, still Firefox and the only updates have been made are auto from Add Block. I see the same adds on this computer on Air Forums and iRv2. I did contact Add Bloch but have not heard back from them.
Don Hardman
1976 31' Sovereign
Old 02-27-2014, 06:48 PM   #8
adonh's Avatar
1976 31' Sovereign
I would allow yours 62overlander.
Don Hardman
1976 31' Sovereign
Old 03-01-2014, 09:00 AM   #9
adonh's Avatar
1976 31' Sovereign
If you have Ad Block Plus and are seeing ads now but have not seen them in the past it may be due to an update from from Ad Block Plus on the February 26th.
Here is what I did that seems to have worked with Firefox. Right click on the ad, then from the drop down menu click on "Ad Block Plus: Block Image". A new window will pop up that is labeled "Ad Block Filter Rule". From this window click on the option listed as "Custom", then click on "Add Filter". This should eliminate the Ad and not effect any Air Forum images that you want to maintain. You will need to do this on all of the ads and it will take time to get all of them.
Don Hardman
1976 31' Sovereign
Old 03-01-2014, 09:05 AM   #10
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
OP, are you referring to the ads for WBCCI, Restoring a Dream, Bash V, Fiddlers Picnic etc. that appear on the upper right of each page? I could be mistaken, but I think these have only begun to show in the last week or so.
Since these AS-related ads are probably coded from within the forum software, I'd guess that adblock etc would not be able to block them.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 03-01-2014, 09:42 AM   #11
adonh's Avatar
1976 31' Sovereign
I guess "Bare Stream Nudist Rally is an "AS-related ad". Oh well I will try zapping it as well. Lets see if it comes back.
Don Hardman
1976 31' Sovereign
Old 03-01-2014, 09:45 AM   #12
TinTin's Avatar
Canmore , Alberta
Ha!! (I'm not seeing that one)
Bob and Nancy
Old 03-01-2014, 09:56 AM   #13
adonh's Avatar
1976 31' Sovereign
Here you go.
Don Hardman
1976 31' Sovereign
Old 03-01-2014, 10:04 AM   #14
TinTin's Avatar
Canmore , Alberta
Could be fun ... then again, all naturists may not be quite as advertised.
Bob and Nancy
4 Corners Unit Thanksgiving Rally 2013 JulianneJ WBCCI Rallies & Events 48 12-13-2013 12:32 PM
Valley of Fires and White Sands Monument 2013 Rally Alumaholic WBCCI Rallies & Events 6 09-24-2013 05:20 PM
Hayes Genesis Brake Controller Question nvestysly Brakes & Brake Controllers 8 08-04-2011 06:00 PM
2011 Mid Winter Meeting wkerfoot WBCCI Forum 372 02-07-2011 03:07 PM
RV to Panama? Dan Dewey Member Introductions 20 02-05-2011 04:36 PM
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Modal Click
