The forums warning system is becoming operational - sounds draconian? Well not really. The warning system is a tool to help moderators track and correct unacceptable behavior on the forum. The system is to be used for flagrant policy violations and instances that require moderators to alter or remove posts.
The system will not be used for harmless mistakes e.g. double posts, large fonts, posts in the wrong sub-forum etc. These are not malicious and we understand that they happen.
Please ask us if you have questions about this system, we are learning as we go along and the goal is to make this an on-line community that is friendly, respectful and polite - where the exchange of knowledge is fostered.
Here’s how it works:
Your meter is under your avatar, it’s not visible by any other forum member.
The meter is set on a 1 - 5 scale.
Only a moderator may change the level.
Points accrued will drop off after 120 days (provided no other infractions have occurred) sort of like points on a drivers license.
If a member reaches 5 points on their meter, they will be banned for 15 days. It is likely that a member would be placed on probation prior to that, however, and all posts by that member would reviewed before they post to the boards.
Here is what an empty meter looks like, as well as a meter with some level showing:
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
I am new to these forums and to Airstream, have been trying to orient myself. I found a post re. above from you from a few months ago, but the last sentence I can see is something like, "here's how it works:"
Then there is no more info. Is the info somewhere else?
Lynne - I sent you a PM with entire post text - not sure why you're not seeing it... there are a couple of pictures as well in the original post. Not to worry - your meter is right were it's supposed to be.
Now if you really wanted full utility out of this I think it would be an even better idea to watch the warning meter fluctuate as we compose our posts.
My emails to the Cheney/Bush administration are being ignored by the White House. If I post them here, will the warn system relay them to the domestic spy network?
YES
Shari
would you rather have a warning or just have posts deleted?
the warning systems seems like a weird sort of intraverts way of asking someone to mind their manners......my guess is that there are only a handful of folks who've received cautions recently...and we can likely guess who they are ....and then there are the sperm sellers and other odd getrichquick posters...but they vanish quickly here.
Well I get this picture when I'm posting, and then I hear this voice...
__________________ Steph in MI Air# 6996- I Hockeytown USA!!
