It's not just execution it is engineering design and specifications. On our new 2012 25FB the first two trips left us stranded and going home. After a good deal of research I found that the tiny under rated change over relay was burning the contacts under full load. No where was this function documented. I fell into it by changing from the primary rear power connection to the front which would reset the relay. I replaced the cheap underrated relay with an actual contactor rated for the full load and completely rebuilt the main electrical assembly to include a new 4 stage converter. Had numerous discussions with the factory about the glaring engineering deficiency. They finally reimbursed me for the parts but not my labor.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
