Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 10-26-2014, 06:27 AM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
2018 33' Classic
Cumming , Georgia
Wireless camera system
Interested in a wireless rear camera for FC 28, not just for backup but for lane changing, etc. when interstate driving. Any advice on brands?
DeltaRon is offline   Reply With Quote
Old 10-26-2014, 06:33 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
While it is expensive, it works. Our Voyager camera is permanently mounted above the Classic's rear window and gets power from a light fixture in the rear roof locker above the twin beds.
Old 10-26-2014, 06:38 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If you have an iPhone, I use THIS ONE that uses my phone as the monitor. I'm very happy with it. Much less expensive than Voyager.
2019 Ford Expedition Platinum
Old 10-26-2014, 07:22 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We also use a Voyager. It is pricey, but it works.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-26-2014, 07:33 AM   #5
2014 28' Flying Cloud
2021 16' Basecamp
Millsboro , Delaware
We also installed voyager, I had factory mount it when we went to J C
I use the video in on our rand Mcnally gps. It is easy to switch between gps map and rear video. It has been flawless
The journey is the destination
SchuHouse is offline   Reply With Quote
Old 01-14-2015, 08:42 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
I mounted an inexpensive webcam to the storage locker over the rear window, looking out through the window. I put a wireless router in the front living room to act as a relay in case the signal from the camera wasn't strong enough. I use a free cam viewer app that is available in iOS and Android. It runs on my iPAD or an Android tablet and my iPhone. Both the camera and the router coincidentally run off 12V.
I had all this stuff on hand, so the cost to me was $0. If you had to buy the camera and wireless router, the pair would probably run you as little as $50 to as much as $200 depending on your selections.
Al
Old 01-14-2015, 08:47 PM   #7
Tincampers's Avatar
Sneedville , Tennessee
Al
Can you tell us the make and model of the router?
Tincampers is offline   Reply With Quote
Old 01-14-2015, 09:18 PM   #8
2003 19' Bambi
Forestville , California
I found an inexpensive $125 baby monitor that I mounted in the back window. The monitor is 5" and is really clear.
http://www.summerinfant.com/wideview
Name:	ImageUploadedByAirstream Forums1421295460.773720.jpg
ID:	230443Click image for larger version
Name:	ImageUploadedByAirstream Forums1421295477.451434.jpg
Mvaug45 is offline   Reply With Quote
Old 01-14-2015, 10:47 PM   #9
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Interesting.......
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 01-15-2015, 04:44 AM   #10
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Rear View Camera on Airstream
I have the Voyager, installed at the factory prior to delivery. This is very helpful for lane changing once one understands the depth perception issues. It covers nearly 180ş, and is very helpful to see vehicles which are overtaking me. Also, when backing up this helps to prevent running over a picnic table or whatever is hidden back there.
I have mine on continuously when on the road, runs off the clearance light power in rear. So, on when lights are on.
A second and third camera can also be added but must be hard wired to the monitor. Only one wireless camera is allowed with the Voyager.
Happy trails and Good Luck
AIR #31871 KQ3H
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-15-2015, 08:12 AM   #11
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I use the same one as Wayne&Sam and have commented on it in other posts. In short, it is perfect and had I had one of these in the beginning, I would have saved several thousand dollars in rear panel replacements before I learned to never ever back up without a spotter. Jim
Jim Flower is offline   Reply With Quote
Old 01-15-2015, 08:45 AM   #12
My router is a Linksys WRT54G Version 6. They are old now, but still available (new and refurbished) on Amazon for less than $30.
Al
Old 01-15-2015, 09:11 AM   #13
Tincampers's Avatar
Al
Thanks, found one for $15 shipped...now to find a camera.
Old 01-15-2015, 09:17 AM   #14
You will want to find a webcam viewer that has the capability to reverse the image left-to-right and maybe flip it upside down, depending on how you mount the camera. Mine is IP Webcam Free, or something like that. It works great, just like having my rearview mirror back.
Al
Old 01-15-2015, 10:35 AM   #15
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
It's your money and your decision, but with camera systems you get what you pay for.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 01-15-2015, 11:03 AM   #16
Tincampers's Avatar
I don't have an iphone so your system is useless to me.
Old 01-15-2015, 12:27 PM   #17
acstokes's Avatar
2009 30' Classic
mrprez,
I'm not trying to convince you to buy my iPhone camera system, only that I've seen and heard of folks investing a lot of time and effort installing a "home-grown" system using cheap components that end up being dissatisfied with the results.
A wired backup camera is one thing, but a wireless rear view mirror camera system is a whole different animal. Just saying.
Fred Stokes
WBCCI #2810
Old 01-15-2015, 01:32 PM   #18
Tincampers's Avatar
OK, thanks. I have lots of time and like to tinker so....
Old 02-26-2015, 01:25 PM   #19
2010 25' FB Flying Cloud
Snoqualmie , Washington
Baby monitor is Interesting solution. Which specific mdel did you get? what do you hook up the monitor and the camera to for power?
Anders79 is offline   Reply With Quote
Old 02-26-2015, 04:03 PM   #20
2003 19' Bambi
I got a Summers Wide View, works great. Really good color monitor and you can have up to 4 cameras. I just hook it to my back window latch and it gives me just what I need. Powered it by an inverter in the trailer.
Need Feedback On Wireless Camera System acstokes Audio, Video & TV 5 07-21-2014 07:01 PM
Wireless Backup-Camera campadk Electronics & Connectivity 31 11-29-2010 08:32 AM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 02:50 PM
Wireless Backup Camera for Your Bambi campadk Electrical - Systems, Generators, Batteries & Solar 39 07-23-2007 07:08 AM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
