Old 05-15-2015, 08:46 AM   #29
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We took power for the Voyager camera from the light under the street side roof locker above the twin bed. We put a rocker switch with LED inside the locker to show when it is powered on.
Old 05-15-2015, 10:01 AM   #30
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
I think the biggest security issue at night is not seeing who is outside or knocking on the door. Any ideas in using a wireless camera with a temporary mount facing the door that would broadcast to monitor inside? This would be removed before travel. What problems would be involved?
openroad118 is offline   Reply With Quote
Old 05-24-2015, 06:45 PM   #31
Boise , Idaho
Temp Camera
The prior mention of the baby monitor which can support 4 cameras, then maybe using a clip to awning or if no awning them 3M foam tape ( yes you will have to renew/replace it ) with either velcro or a magnet/metal fender washer on either the AS skin and base of the camera which ever works for you. If hard power is an issue ( some cameras are AC ) look for the battery powered camera and portable monitor. Another set of batteries to recharge.
IdahoStat is offline   Reply With Quote
Old 05-25-2015, 08:31 PM   #32
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Is the Voyager camera useful for backing into a campsite, or just seeing who's on the road behind you?
kscherzi is offline   Reply With Quote
Old 05-25-2015, 08:38 PM   #33
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Mirrors and a spotter are more helpful to me for backing up though there is some value in seeing behind the trailer any time and in backing up, turn up the volume so the spotter's voice can be heard that way.
As a wider rear view on the road it can't be beat. Very happy we got it.
Old 05-26-2015, 09:09 AM   #34
2016 30' Classic
Erie , Colorado
I use mine all the time for the backing process. I do a fair amount of solo camping. During the initial maneuvering I use the mirrors and Mark II eyeballs from the drivers spot. Voyager gets a few glances. Once I am centered and aligned I use it to determine my stopping point. That works well.
Mine is tilted so that in the bottom left and right corners of the screen I just see the edges of the end of the bumpers. And with a bit of learning it's easy to get within 3 feet of the rear bumper and stop.
On the road besides what's behind you I like it during a passing phase. Once I can see the other vehicle in the Voyager I know I have cleared them and can start moving back into the non passing lane. Invaluable.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 06-03-2015, 07:19 AM   #35
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Hello, I purchased the Voyager system yesterday and would like to see exactly where the camera is placed at the rear of the AS. I have a 25FB EB. Also does that position allow view of the entire rear bumper area for backing up at the same time still work well for a "rear view mirror" for highway travel?
TRIPPPIN is offline   Reply With Quote
Old 06-04-2015, 10:09 AM   #36
2016 30' Classic
Erie , Colorado
Mine is about 6-8 inches below the center running light. Tech pulled power by pulling the running light and running the Voyager power up the inside wall and connecting into the power for the light. While driving turn on the lights on the TV and the camera is powered.
I have mine tilted and can just see the ends of the rear bumper in the lower left and right corners of the screen. Can't see directly down on the bumper but can get close enough backing up. At the top I see just above the horizon line so seeing upcoming traffic or traffic I have just passed works great.
Gary
2015 Classic
ProPride
NVPN
Old 06-04-2015, 10:22 AM   #37
dznf0g's Avatar
Oswego , Illinois
Ditto to everything said here.
-Rich-
Old 06-06-2015, 05:34 AM   #38
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Installed by the folks at Jackson Center pre-delivery
Airstream_Rear_Camera_06.06.15 by Tommie Lauer, on Flickr
Airstream_Rear_Camera_06.06.15-2 by Tommie Lauer, on Flickr
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 06-07-2015, 07:35 AM   #39
TRIPPPIN's Avatar
Thank you. Will be installing Voyager Camera this week. Next I am going to figure out how to get a second camera for viewing down the curbside.
Old 06-07-2015, 06:37 PM   #40
Msmoto's Avatar
2007 25' Safari
Images: 135
Second Camera
As I understand it, the second camera must be hard wired. So, having it on the trailer itself may defeat the purpose of a wireless camera.
AIR #31871 K4MTL
Old 06-28-2015, 03:11 PM   #41
Vineland , New Jersey
Looks like you just use the cable tie
is that right
Flowers780 is offline   Reply With Quote
Old 07-16-2015, 08:39 PM   #42
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
This may be a stupid question, but for those that installed this before, what type of screws were used in mounting? I was not sure if where this is mounted on the rear of the Airstream if there was a support member under the skin that was being tapped into or just screwing into the outer skin.
Done many things on the inside of the Airstream but none on the outside and was not sure how it was really attached to the skin. Thanks for helping easing my hesitation into drilling into the outer skin.
silverlabs is offline   Reply With Quote
Need Feedback On Wireless Camera System acstokes Audio, Video & TV 5 07-21-2014 07:01 PM
Wireless Backup-Camera campadk Electronics & Connectivity 31 11-29-2010 08:32 AM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 02:50 PM
Wireless Backup Camera for Your Bambi campadk Electrical - Systems, Generators, Batteries & Solar 39 07-23-2007 07:08 AM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
