Old 09-16-2012, 06:45 AM   #1
Haoleman's Avatar
1972 Argosy 20
Lanesboro , Minnesota
Images: 20
Which TV Antenna?
I just removed the Yagi crank up antenna from my 72 Argosy in prep for paint and was wondering which digital antenna assembly would be the most appropriate. The base is about 6" round with about a dozen screws holding it in place.
Haoleman is offline   Reply With Quote
Old 09-16-2012, 07:01 AM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
RoadStar 3000
I replaced my winegard Senasr antenna several weeks ago with the new winegard Roadstar 3000. This is an omnidirectional antenna that can be mounted directly to your trailer. I am still in the research mode. The directions for the antenna says you must have it 18" from any objects like skylights, air conditioner etc. Directions also state that height is a good thing. With these factors in mind I made an adapter so I could mount the antenna on the existing lift arm for the Sensar antenna. I have been traveling in many rural areas recently and have had good results. For example in one rural area with the antenna down I was getting 22 stations, with it in the up position it increased to 30 stations from three different cities. As with all HD stations, if it is windy and the antenna starts to wiggle the reception will degrade. I will try to post some photos in a couple of days
fltlevel510 is offline   Reply With Quote
Winegard HA-0130 antenna... might buy Lothlorian Audio, Video & TV 3 03-10-2014 09:56 PM
Alternative TV antenna or bypass WineStream Audio, Video & TV 10 04-02-2012 06:48 AM
Roof crank up antenna wire goes where ??? dryenko Audio, Video & TV 10 01-17-2012 07:54 PM
Help with antenna location and setup dznf0g Phone, CB & Ham Radio 0 10-16-2011 08:46 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
