Old 06-04-2016, 06:42 PM   #1
Airstreamer In Training
FCStreamer's Avatar
2014 30' Flying Cloud
What is this plug for?
This converter is plugged into a 110V outlet where the blueray player is. What's it for?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 06-05-2016, 10:01 PM   #2
Viggen's Avatar
2016 19' Flying Cloud
Davidson , North Carolina
Use that plug when using inverter and not connected to shore power
Viggen is offline   Reply With Quote
Old 06-06-2016, 06:05 AM   #3
FCStreamer's Avatar
My apologies, I wasn't clear. I meant the black plug I unplugged and placed on the shelf. That is providing power to something but I don't know what.
Old 06-06-2016, 06:22 AM   #4
W4NT3D's Avatar
2016 27' Flying Cloud
Saint Robert , Missouri
It might be power for radio.
W4NT3D is offline   Reply With Quote
Old 06-06-2016, 06:55 AM   #5
paiceman's Avatar
Upper St Clair , Pennsylvania
Can you show what the back and far side look like.
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-06-2016, 01:59 PM   #6
FCStreamer's Avatar
I thought that also, but the radio still worked even after I unplugged it.
Does the TV antenna require any power?
Old 06-06-2016, 02:00 PM   #7
FCStreamer's Avatar
The back is just a regular two prong electrical connector that connects to the wall outlet. I'll take some more pictures next time I'm out there.
Old 06-06-2016, 02:42 PM   #8
2005 19' Safari
GLENDALE , AZ
It looks like a "Sunny" brand switcher power supply. Most likely it supplies 12 volts to something in the cabinet. What is plugged into this device? (Not the 120 VAC plug, but the other end of the power cable that comes out of this box.)
Old 06-06-2016, 02:54 PM   #9
FCStreamer's Avatar
I don't know. It disappears into the cabinet.
Old 06-06-2016, 03:14 PM   #10
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Unplug it and see what stops working.
Old 06-06-2016, 03:17 PM   #11
richw46's Avatar
Lexington , Kentucky
Sunny makes an AC/DC adapter. If you have a device that uses a 110 vac adapter to a DC voltage, the adapter will let you run your device from 12 vac
Example, my laptop requires 19vdc power. At home I use the adapter that came with it, plugs into a 110 wall socket. When I travel, if we're boondocking, instead of firing up the inverter to convert 12vdc to 110vac then using the supplied adapter to drop it back down to 19vdc, I simply plug in the 12vdc adapter which boosts 12vdc to 19vdc. House batteries last longer.
So you have something like that also, a device that requires some DC power but comes with a 110vac plug. You can run it off the inverter but the Sunny adapter will just use the 12vdc battery to provide the necessary DC power for your device.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-06-2016, 03:37 PM   #12
FCStreamer's Avatar
He he. I like how you think.
I tried it. The blue ray player and the radio still worked. I couldn't figure out what stopped working. Must not be very important...
Old 06-06-2016, 04:35 PM   #13
Llando88's Avatar
2016 30' Flying Cloud
Not near my coach, but I seem to recall there is a 1:2 video splitter somewhere in that region...could that be it?
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
ďCharacter is doing the right thing when nobodyís looking. There are too many people who think that the only thing thatís right is to get by, and the only thing thatís wrong is to get caught.Ē - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 08-26-2016, 09:15 PM   #14
Sainte-Julie , Quebec
Yes it is a 1:2 HDMI splitter
For the dvd player to be play on the 2 TV
laperrl is offline   Reply With Quote
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 04:44 PM
Cig Plug Voltmeters Pick Electrical - Systems, Generators, Batteries & Solar 2 01-27-2003 09:39 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 06:24 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 06:33 PM
