Old 03-06-2016, 07:07 PM   #29
2015 23' Flying Cloud
Livermore , California
Has anyone had Bay Area Airstream Adventures do this install?
cactusjk is offline   Reply With Quote
Old 03-06-2016, 07:49 PM   #30
Sounds like Airstream Adventures did the install so I should be able to get Bay Area Adventures to hook up with them.
Originally Posted by chaeha View Post
May I ask who did your install? Local Airstream dealer?
Old 03-06-2016, 08:27 PM   #31
2016 30' Classic
Erie , Colorado
Matt.
WeBoost devices have two antennas. One External and One internal. I don't think there are any data lonely boosters. As to 'slapping on a hotspot' maybe you can elaborate on your question. Not sure what you mean.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 03-07-2016, 08:27 AM   #32
2014 30' FB FC Bunk
Golden , Colorado
Originally Posted by spelunkus View Post
I'm looking to do a similar install in my 25' Eddie Bauer.
If you only need the cell coverage for data (not phone calls), can't you just slap a hotspot on the internal antenna and not worry about inside/outside range?
BoldAdventure, did you setup that internal antenna so you can make phone calls?
Matt
This is exactly what I have done. I have a Verizon MiFI, which has two antenna ports. I connect the output side of the Weboost to an antenna splitter, which then connects to the MiFi. I make all voice calls over Skype anyway so this works out perfectly for me. I keep the MiFi velcro'd to a wall inside the pantry where the weboost is also at. Works great for my needs!
bbdo is offline   Reply With Quote
Old 03-07-2016, 08:30 AM   #33
Do you still have the Weboost internal antenna along with the Mifi connected to the splitter? If so what cabling/connectors are needed?
Old 03-07-2016, 10:11 AM   #34
The 3G store recommended:weBoost RV 4G 60db 5-Band Repeater Kit - 470201 [700/800/1900/1700/2100mhz]
if only using parked since this one has much better inside coverage. Will still be using the Sure Call Omni antenna. Am I missing something?
Old 03-07-2016, 10:32 AM   #35
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Just going to leave this here: http://www.air802.com/antenna-cable-...lent/?ctid2=20
Better cable, custom ends no connectors like that over priced trash from 3G store. good service, fast shipping.
If it where me, I would ignore 3GStore's advice and buy the Drive. Second the Surecall is for the external antenna, not internal. It's a better antenna then the small magnet that comes with it. If you're just parked in town though, the small one should suffice. If you're like us, out in the boonies, the Surecall is worth the investment.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-07-2016, 11:28 AM   #36
Also saw this one: weBoost Drive 4G-X + RV Trucker Essentials Kit | 470510-RV on the Wilson site. Starting to get pretty confusing...
Old 03-07-2016, 12:59 PM   #37
2016 30' Classic
Erie , Colorado
Cactus you may save money not buying the 3G kit. The kit you mention has an outdoor directional antenna. If you don't plan to use a directional AND really want to install the SureCell then you don't need it and probably can make your own bundle.
Gary
2015 Classic
ProPride
NVPN
Old 03-07-2016, 01:44 PM   #38
Please shoot me a PM if you can help me with this large technical purchase. Thanks,
Old 03-07-2016, 01:45 PM   #39
2014 30' FB FC Bunk
Golden , Colorado
I only have the MiFi connected.
Old 03-07-2016, 03:26 PM   #40
Los Angeles , California
Originally Posted by ghaynes755 View Post
Matt.
Gary,
I was just asking if the reason that people are discussing the internal antenna strength is because they want to make actual telephone calls. If you don't care about that and only want cell coverage to use the internet, then you would just put a mifi right next to the candy bar and get all the range you need via wifi. I wanted to make sure I wasn't missing something obvious.
Matt
2016 Ram 2500 Cummins Diesel "Che (车)"
2016 25FB Eddie Bauer "Jia (家)"
Instagram: https://www.instagram.com/travelingmonkeys
Blog: http://hellotravelingmonkeys.com
spelunkus is offline   Reply With Quote
Old 03-07-2016, 04:25 PM   #41
That is a good point. if you place the Jetpack close to the candy bar antenna you should have data throughout the trailer. Then for voice you just need to be within LOS of the candy bar.
Gary,
Matt
Old 03-07-2016, 08:54 PM   #42
KYAirstream's Avatar
Northeastern , Kentucky
For those of us less technically savvy, what does the MiFi accomplish that a hotspot on one's phone doesn't?
KYAirstream is offline   Reply With Quote
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 12:41 PM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 08:47 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 12:54 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 11:01 PM
