Old 01-14-2018, 09:42 PM   #197
2016 FC27FB - F350 2017
2016 27' Flying Cloud
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
It is a rectangular black slim box, velcroed to the bottom of the cabinet. No markings or brand. I figure is the one that came with the unit.
2016 FC27FB - 2017 F350 Platinum 6.7L Diesel, Crew Cab. - 2017 Audi A7S - 2018 Land Rover Discovery HSE
Accuracy International + SB, various.
GSD Sigrid - Fort Lauderdale, FL, Golden, CO and Silverthorne, CO
Vitaver is offline   Reply With Quote
Old 01-14-2018, 10:19 PM   #198
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by Vitaver View Post
The outside antena on top is right above the dinette. On the cabinet right below is the device and right under the cabinet is the inside antena. The AS dealer did the initial installation and at my request reset the outside antena using a metal plate for base as the instructions indicate.
It sounds like your antenna are too close together and creating a feedback. Do you see red instead of green lights sometimes? Try to remount your outside antenna at the opposite end of the trailer.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 01-14-2018, 10:44 PM   #199
Only the green light shows when powering up, solid and stays that way.
I did additional testing on my iPhone X and Verizon Jetpack. When physically touching the antenna, the signal strength on the phone goes from one bar to all 4. 10 inches appart it goes back to one. The Jetpack did not show any difference: close, away or with the Weboost 4X powered off.
Old 01-14-2018, 10:55 PM   #200
This Surecall antenna you place inside the RV, is this one? https://www.amazon.com/SureCall-Sign...=surecall+Omni
If not which please? Thank you
Old 01-15-2018, 09:10 AM   #201
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
The slim black box you speak about sounds like the "candy bar" antenna which is only good when touching the back of the cell phone and is useless if it is more than a foot away. Your installation is not according to the manufacturer specs for separation. These boosters work but you need to follow the recommendations. There are several threads here and you tube videos on the various setups
I have the 4g-x drive with all we boost brand equipment including 400 lmr cable, omni directional antenna at one end of the trailer and the panel antenna at the other end mounted under the cabinet above the dinette and it works well at the dinette. We had the candy bar antenna initially but since it had to be on the back of the phone to work it was only good for one user so we upgraded to the panel.
TRIPPPIN is offline   Reply With Quote
Old 01-15-2018, 09:28 AM   #202
mojoe7009's Avatar
Green Cove Springs , Florida
Originally Posted by interstateflyer View Post
Would you happen to know the model of your Indoor Flat Plate Antenna? I've noticed that they sell a rectangular white low profile box antenna and a couple of rectangular black ultra slim models.
Itís called a Wilson Indoor Flat Panel Antenna- White. Picture Attached. Click image for larger version
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 01-15-2018, 09:42 AM   #203
mojoe7009's Avatar
No, the SureCall Omni Antenna is an outdoor antenna. The outdoor antenna must be placed on the roof as far away from your WeBoost as possible (minimum of 12 ft. if possible). I used the Wilson Flat Plate Indoor antenna mounted to the ceiling in front of the refrigerator with VHB Velcro strips (no drilling).
https://3gstore.com/product/3047_3g4...i-antenna.html
Old 01-15-2018, 09:43 AM   #204
mojoe7009's Avatar
Get with the guys at the 3gstore.com. They are super helpful and competitively priced. They will hook you up.
Old 01-15-2018, 12:50 PM   #205
Yes, my experience also.
Old 01-15-2018, 12:51 PM   #206
T have this one mounted on a solar panel at the front of my 25FB.
https://3gstore.com/product/3047_3g4...yABEgKE4vD_BwE
Old 01-24-2018, 07:01 AM   #207
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
I'm also debating on which INSIDE antenna to buy -- I'm not a fan of the candy bar that came with the kit. Question: What would happen to the signal strength if I spray painted either the wall mount or ceiling mount antenna to match the decor? These antennas stick out like a "sore thumb"!
glcmranger is offline   Reply With Quote
Old 01-24-2018, 07:57 AM   #208
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
My guess is paint would not cause any degradation as long as it wasn't metallic. The WeBoost support staff are very helpful - give them a call and ask them.
My limited experience with the WeBoost systems indicate the larger antenna is much better.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 01-24-2018, 01:15 PM   #209
GLCMRANGER - Sue
Does anyone know what connectors I need to connect the Wilson400 Low Loss 20 foot cable to 1) The Surecall Omni Outdoor Antenna, and 2) a connector for the Weboost Drive? The thick Low Loss Cable Male Connector is huge!
Old 01-24-2018, 04:03 PM   #210
mojoe7009's Avatar
WeBoost adapters N to SMA $7.99 and Wilson SMA/N extension cable
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 12:41 PM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 08:47 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 12:54 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 11:01 PM
