Old 10-02-2016, 09:32 AM   #127
2015 23' Flying Cloud
Livermore , California
With regard to Jetpacks, how much data is eaten up if you use an Apple TV or other streaming device?
cactusjk is online now   Reply With Quote
Old 10-02-2016, 09:36 AM   #128
Lily&Me's Avatar
Normal , Illinois
I haven't had a Jetpack for over a year...did love it, but find the convenience of the cellular data within my IPad Mini so much more convenient, especially when traveling.
You really can't do much streaming, unless you want to pay really big bucks.
I had 14 or 15 GB a month, and could maybe watch one movie on that, toward the end of my data month, to avoid overage.
I switched to a home WiFi, and dropped my Verizon to 2GB/month, unless traveling.
The reduction in Verizon more than paid for adding the WiFi at home, and I've been very happy with it.
Maggie
Old 10-02-2016, 01:21 PM   #129
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Yeah, I wouldn't 't plan on streaming videos via cellular data unless I had an unlimited data plan. Even then, I'd be careful not to consume more than 200GB per month, to avoid calling too much attention to myself.
My DVD player still works, so I'm good with that.
Rocinante is our 2014 International Signature 27FB
Old 10-02-2016, 01:40 PM   #130
FCStreamer's Avatar
2014 30' Flying Cloud
Depends on the quality, but suffice it to say it's "a lot".
Streaming and cellular networks don't mix.
I have an unlimited plan on my iPad but rarely stream anyway. I'm a big iTunes nut, but enjoy it mostly at home with unlimited internet.
On the road, I rely on saved stuff.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-27-2016, 12:45 PM   #131
2014 30' FB FC Bunk
City , Maryland
During the process of ordering the drive 4g-x today with the 3g store, I mentioned that I wanted to upgrade the internal to gain more coverage. They mentioned that due to the limited gain of the amplifier that I would not gain additional/better coverage by upgrading to another internal antenna.
I have read thru various threads and it seems like everyone here has gotten better results changing out the internal antenna.
Whats everyones take?
My setup will be like most: weboost drive 4g-x, two surecall Omni directional's & the yagi directional including the pepwave surf soho (when they become available).
Alumalarkey is offline   Reply With Quote
Old 10-27-2016, 08:28 PM   #132
Rivet Slave
Rocinante's Avatar
We went with Wilson's panel antenna vs. the candybar antenna provided with the 4G-X. We like it, though it's possible we're fooling ourselves. I hate to argue with experts at the 3G store, because they are generally so helpful. Maybe chat with the folks at WeBoost/Wilson to see what they say?
Old 10-28-2016, 06:14 AM   #133
lewster's Avatar
Naples, FL , Hood River, OR
I use Wilson's inside panel antenna, along with the Sure Call Omni outside antenna in every 4G-X installation that I do. I have found that there IS a difference in usable range! You need to be within 3 feet of the candy bar to get proper response, but the panel increases this distance to 10-15 feet.
Interesting, but it was on the advice of a the techs at 3G Store that led me to the panel antenna initially. I don't know why they would not support that now.
Old 12-31-2016, 05:59 AM   #134
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
I use a truckers antenna I mounted to the side of AC unit, run cable through ref ridge vent ( drilled hole in lower aft side of vent under grill and avoided messing with that. Fished cable down and out to comm area I set up under seating by tv with easy access. There is the weboost and a cable runs aft to wall under table that we keep stowed to the wall mounted antenna. We haven't had much road time to see how it works, but that's what we're going with for now.
DBLee and Southern Belle on the road
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 12-31-2016, 12:05 PM   #135
interstateflyer's Avatar
2017 25' International
Los Osos , California
My Sure Call Omni came with Wilson 400 Ultra Low Loss coaxial cable. The cable is 3/8 inch diameter and seems that it could be a challenge routing it through the trailer. Has anyone successfully used a thinner and more flexible coax?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 12-31-2016, 04:25 PM   #136
lewster's Avatar
Weboost install
I only use ULL ( ultra low loss) cable for my cell booster installs. It's just not worth the possibility of noticeable signs loss with anything else.
I don't have to cut large diameter holes though, as I put the N connections on myself, so the hole size is just slightly larger than the cable diameter. 😄
Lew Farber
Old 01-06-2017, 03:40 PM   #137
mojoe7009's Avatar
I intend to install my Wilson 4G-X in the cabinet above the TV in my 2017 Classic. Which is right next to the fridge and will use the fridge vent to run the cable into the trailer. Two questions for you Lew:
1. Do you drill a hole in the side of the vent to route the antenna cable, then seal it up or is there a different/better method?
2. How far back or forward on the roof should I mount the antenna on a 30 ft trailer given the 4G-X will essentially be midship?
Breathe in, Breathe out, Move On!
2017 Classic
2016 Ram 2500 CC 4X4 Diesel
ProPride 3p
Breathe In, Breathe Out, Move On
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 2500 Limited CC 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
mojoe7009 is offline   Reply With Quote
Old 01-06-2017, 05:15 PM   #138
2017 Classic
ProPride 3p
I'm considering a similar install on my 2017 25FB. Have you decided on how you are going to power the 4G-X? Will you go for both 120AC and 12vDC?
Old 01-06-2017, 06:23 PM   #139
lewster's Avatar
You only need the 12VDC as it will be more practical and it's available when off-grid. You should use either the switched 12VDC outlet adapter OR install a switch in the line if you hard wire the 4G-X, as it draws almost an amp when on and you certainly won't need that draw if you are not using the amplifier.
Old 01-12-2017, 06:01 AM   #140
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
The more I research the WeBoost and the antennas associated with it the more confused I become.
For instance, in installing a WeBoost Drive 4G-X with a Omni antenna on the outside of my 20' FC, I'm told if I also install a SureCall dome on the ceiling inside, the antennas have to be at least 10' apart, 15' is better so they don't create a 'loop'. But what about the panel antenna Lewster talks about? Where do you place that and will that work? How close can they be from each other, as the panel is directional? I want to avoid using the 'candy bar' antenna and it's limitations. What model of panel antenna is being referred to here?
openroad118 is offline   Reply With Quote
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Brake install -INSTALLATION/ADJUSTMENT/WIRING Sharon Lee Brakes & Brake Controllers 10 07-21-2002 07:47 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
