Old 09-04-2016, 09:19 AM   #1
abone's Avatar
2017 27' International
Richmond , British Columbia
Voyager Rear Camera Pairing
Hi,
We just picked up our 2017 27FB last week complete with the factory installed Voyager rear camera, model # WVOS541.
Hooking up the remote dash monitor is easy, basically a plug in and push a button to pair...however it can't find the camera during the pairing process.
Trailer is hooked up, I've tried with the truck running, and also with the park lights on as per the manual. Trailer battery is connected and operational.
I'm stumped. It searches for 60 seconds and fails, over and over.
Anyone connected one of these things before?
Thanks!
(yes I tried searching for a similar thread to no avail)
2017 27FB Intl Sig
2017 F350 Super Duty
abone is offline   Reply With Quote
Old 09-04-2016, 10:08 AM   #2
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
Yep. Same here.
We have a 25' 2017 with the same equipment. Our experience has been the same. The dealer could not help.
Called the Voyager manufacturer and they said the antenna needed a direct line of sight to the monitor in the truck. Said the signal will not go through the aluminum she'll of the airstream. They recommended on mounting the antenna the driver side of the trailer so signal can "bounce" off the driver mirror?
I got an extended antenna from the manufacturer. It is a taller antenna with a 10' cable. The cable screws into the camera. This allows to move the antenna to a more central location on the trailer.
I have temporarily placed the antenna on the "heat shield" between the frig exhaust and the AC unit. It immediately connected. I still need to do some road testing to see if this is a final solution.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 09-04-2016, 11:46 AM   #3
abone's Avatar
Thanks for the reply. Good to know I'm not alone.
So they sell and charge for a system, on an Airstream, that can't read a signal through aluminum without significant modifications? That makes a lot of sense!!
My dealer handed me the box during the orientation and had no clue what it was. I had to tell them.
2017 27FB Intl Sig
Old 09-04-2016, 12:04 PM   #4
2007 22' International CCD
I ended up getting a fully wired three camera system. Another umbilical to plug in, but I can see behind and also on either side as needed. Going to be a PITA and engineering nightmare to install in a tidy manner, but I will document when done.
From Rear View Systems, through Camping World assuming I remember correctly.
KE4GNK/AE
Old 09-04-2016, 12:54 PM   #5
abone's Avatar
Whaddya know, I got it to work.
I turned the truck running lights on, and it connected immediately. Didn't even have to press the pair button on the monitor.
It won't work if the truck lights are in "daytime" run mode, or off. Only when headlights or running lights are on.
I think my problem yesterday was I had the trailer plugged into the house power. Can't remember for sure, but I did unplug it this time and as soon as I turned my truck running lights on, bingo, it worked. I even heard the wife cursing me from the back of trailer so audio works too.
I take back everything I said and thought about Airstream (not the dealer though, that still stands).
2017 27FB Intl Sig
Old 09-04-2016, 01:15 PM   #6
(Edit)
Search the Camping World site for item number 82550. Not exactly cheap, but it's seriously heavy duty stuff. Side cameras are teardrop aluminum enclosures that I plan to flush mount near the front of the AS. I need to bench test to see camera coverage first. Drilling the new 3/4" holes in pristine side panel aluminum will be the scary bit.
Might be possible to get it direct from Rear View Systems cheaper...
KE4GNK/AE
Old 09-04-2016, 05:48 PM   #7
FishByFly's Avatar
Oak Park , Illinois
abone, I worked on mine today too. I had a couple of things going on. The longer "extended" antenna screwed direct to the camera seems to work. Going to continue to monitor that placement before trying to relocate the antenna midship as described earlier. I found that sometimes it immediately connects without having to search for the signal. If everything is plugged in and I turn on the running lights, I have to search to connect.
FishByFly
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
Past: 2005 30' Safari Bunkhouse
Past: 1986 28' Excella Twin
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Old 09-04-2016, 05:51 PM   #8
FishByFly's Avatar
Oak Park , Illinois
By the way, I had the very same experience with my dealer. A box was handed to me with no idea how it worked. When I asked them what I needed to do to connect the camera, they told me that didn't know. That was after my three hour walk through.
FishByFly
2010 F250 Lariat
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Old 09-05-2016, 06:07 AM   #9
abone's Avatar
I tried my camera again, with the trailer hooked to house power, and it worked. So now I'm not sure why it suddenly started to work, other than having the truck lights in the right position ... I thought I had tried all positions the previous day. As long as it works when I take it on our first trip in a few days I am happy.
Regarding orientation - When buying our trailer I almost bought off another dealer, but decided not to because they were a 4 hour drive away, plus didn't have a 27FB in stock or on order. They have full hook up on their lot, set you up for an overnight stay with a fridge full of refreshments, and make sure you know how to operate everything before you leave. In addition, they only sell Airstream and Class A motorhomes so really know the product. That
is a great way to introduce a newbie AS owner.
2017 27FB Intl Sig
Old 09-05-2016, 10:09 AM   #10
2016 19' Flying Cloud
Morrow , Ohio
I have factory installed Voyager on 2016 . Walk thru salesman could not get camera to work . He went and got " tech " who walked to truck cab and reached in and turned on lights . Camera popped right up . It's lovely . On trip home I immediately came to a detour and was sent to a area that would have been a problem without that camera . Love it .
Tech said lights must be on for camera to work .
Ninanet is offline   Reply With Quote
Old 09-05-2016, 11:49 AM   #11
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
Yep, I was just going to chime in with the "running lights" have to be on. Works everytime. Happy travels!
Longboard6 is offline   Reply With Quote
Old 09-05-2016, 11:59 AM   #12
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Voyager
Since the camera gets power from the rear trailer light, you have to turn your TV running lights on. My procedure is to 1) start truck (diesel) and let it idle for a couple minutes to let batteries settle down. 2) plug in monitor and power on. 3) WAIT 30 seconds then turn running lights to ON position. I pair in 1-2 minutes.
DeltaRon is offline   Reply With Quote
Old 09-05-2016, 02:37 PM   #13
2014 25' Flying Cloud
Herkimer,NY , soon to be Keswick,VA
I've had one for 3 years and love it!!! Works just fine with our 25' FC IF the truck lights are turned on. This is a fabulous product and well worth the nominal cost IMO. Happy traveling.
herkvet is offline   Reply With Quote
Old 09-06-2016, 02:47 AM   #14
FishByFly's Avatar
Oak Park , Illinois
I first real trip was a night departure. The camper paired as all explain. Once we got off of city streets, the camera would drop signal. It continued to drop and gain the signal for the next three hours. Tech support thought the antenna was loose. I hope the newer and longer antenna solves the problem. Also found that the auto light mode on the truck is not a good option as they tend to turnoff when departing my storage facility.
FishByFly
2017 25' Safari FB
2010 F250 Lariat
Voyager rear view camera image upside down jamieb1086 Audio, Video & TV 9 04-04-2017 09:03 AM
Voyager back up camera 4t9ers Electrical - Systems, Generators, Batteries & Solar 43 11-12-2016 10:37 AM
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 45 01-21-2016 08:50 AM
Voyager WiSight Camera works 50% of the time. Ted S. Electronics & Connectivity 14 08-20-2015 09:54 PM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 06:32 PM
