Those 2 ports in the AV cabinet are just for power. There's a loose HDMI cable inside the boxed-in area where the DVD player is, intended for use with a satellite receiver (there should also be a coax cable terminating inside that box, for the line in from the satellite connection in the Furrion coax connection outlet street-side aft.) If you want to connect something like an AppleTV or an iPad to HDMI in a fairly hidden way, that loose HDMI should do what you need.
— David
