Old 12-04-2013, 06:20 PM   #1
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Upgrade to Batwing Antenna
The crank-up gear has broken on our antennae and we are thinking about switching the whole unit out for a batwing antennae that doesn't need to be cranked up. Any thoughts on this. What brand is the best? How difficult is it to switch out the old antennae for a newer digital kind? Thanks!
kswelsh is offline   Reply With Quote
Old 12-04-2013, 06:53 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Look into the 'Jack' antenna. Amplified, directional and very cool!
Old 12-04-2013, 08:04 PM   #3
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Thanks - I checked this out and bought one from Camping World. It looks fairly simple to install. I think it will be a Merry Christmas present to hubby (even though he will have to install it!). I appreciate you pointing me in this direction.
Old 12-05-2013, 10:07 AM   #4
2006 19' Safari SE
Hayes , Virginia
I certainly hope you do not have the problems I have been having since September trying to get my "Jack," up and working. Dealing with the company, at first, was a complete nightmare. Within the past week, another supervisor stepped into the picture and we are working on the problem now. The problem: Voltage to roof/antenna. 2 - 3 lights at Signal Meter, TV channels scanned many times. TV disconnected from satellite antenna and installed on the Jack antenna indicating TV working. Line from Wall Mount to antenna connection bypassed from trailer and external line used to insure connection not the problem--it wasn't. Rather than taking the antenna back, they started me on a hunt that is still going on. I have been working with company over 45 days (E-bay cut-off for refund). Good Luck...I am sure it is a great product once installed and working. This just F Y I
mocus is offline   Reply With Quote
Old 12-05-2013, 11:09 AM   #5
lewster's Avatar
Sorry you are having problems. The moral of this story........ Buy LOCALLY from someone you trust and will take responsibility for failed products.
I NEVER install any part that I do not provide as I can not stand behind them!
Old 12-05-2013, 01:01 PM   #6
SteveH's Avatar
Common Sense , Texas
There's a issue with using a Jack antenna to replace the original in an Airstream because the Jack has an amplifier built in, and therefore needs 12 volts sent up the coaxial cable to power it. The Airstream is equipped with an amplifier in the switch plate, and does not provide power to the antenna. The Jack antenna will not work with the amplifier and input switch plate that is normally installed in the Airstream.
Regards,
Steve
Old 12-05-2013, 01:15 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Steve
The Winegard plate is not a signal amplifier.... it is a power supply. It does infraction send 12v up to the antenna then strips the voltage from the downstream output.
Get out your dvm and check at the ant connection.
The Jack works just fine with our factory supplied wall plate.
Old 12-05-2013, 03:37 PM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If you are still having problems, once you get electric and amplifier straightened out, it might be crank up is the way to go. I experienced picture fade in last CG when AS's passed our campsite, too much shiny metal reflecting signal also regular antenna wouldn't bring in signals until cranked up, unless stations were very close.
ps. antenna will bring in all signals if they are there, analog or digital
Old 12-06-2013, 05:39 PM   #9
2006 19' Safari SE
Hayes , Virginia
Talked with the company today to find out what I could try next. I have used the AS Wall Mount and the one provided by Jack to no avail (they are almost identical). Correct voltage detected at antenna head. I can also get 2 - 3 lights lit on the SurLock Signal Meter, when positioning the antenna in various directions. In order to bypass everything between the Wall Mount and the antenna, I ran a line of RG6 from the Wall Mount, out the door, to the roof, and connected to the antenna. I took the SureLock Signal Meter to the antenna and connected it. Jack amplifier is in head and my reception was no different on the roof. This is the second Antenna Head that I have tried to no avail.
I mentioned to the technician supervisor everything I had done and he still didn't have any idea what the problem could be. Then, I mentioned that someone on the AS forum suggested possibly the aluminum might be the culprit. He said he never thought of that but would take it to engineering and get back to me beginning of next week. Then I asked, if this antenna will not work on the AS will I get my $115 back. He said he doubts a refund would be given.
There is nothing mentioned in their advertisements concerning make of trailer the antenna would not work on...it insinuates it is the "best," antenna on the market.
What do you think about pursuing this to a higher level if I do not get resolution from the tech I am working with. I have been working on this since September with the company and it sure has become very frustrating. In addition, it would be nice to know if anyone has used the Jack successfully on their AS?
Old 12-06-2013, 05:45 PM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I installed on in our PanAmerica.
Was a 3 minute swap. Works great!
Sitll using the old sensar head in my 34 excella.... both work exactly the same.... different coaches ( both 34'), same televisions. Same results.
Old 12-06-2013, 06:14 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
This seems like a great product to maximize reception, but I have a question: Is there a problem with the Jack antenna (the version that you replace the old batwing with and then raises /lowers) fitting next to the AC shroud when it's folded down on a 19' Airstream? I ask because if memory serves, the standard batwing folds down beside the shroud (as well as the solar panel sitting in front of the shroud).
TB & Greg and Abbey Schnauzer
#3954
Old 12-06-2013, 06:19 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Dunno.... on both of mine they fold.fore and aft. There are many feet at least between antenna and anything like the a/c. Its like acres of roof up there on a triple axle!
Ill post photos from a different computer later.
Old 12-06-2013, 09:09 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Originally Posted by AtomicNo13 View Post
Dunno.... on both of mine they fold.fore and aft. There are many feet at least between antenna and anything like the a/c. Its like acres of roof up there on a triple axle! Ill post photos from a different computer later.
Def interested!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-06-2013, 09:25 PM   #14
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Another thought for those interested.
If you plan to use the old existing Winegard crank up but replace the batwing/ sensar head it is a 100% direct swap. If you plan to eliminate the crank up deal and use the Jack fixed mount, the Jack needs an optional mounting plate to cover up the mess leftover from the Winegard mount. Not fancy but a clean mount. Also be aware there are 2 different batwings which look almost identical .... powered and non powered. Make sure your existing wall plate is actually a power supply not a signal amp. I do not believe AS ever used the kind utilizing a signal amp. A signal amp will not provide 12 volts to either antenna head resulting in a non working antenna. Verify this a the Winegard site by checking descreptions and part numbers.
Winegard HA-0130 antenna... might buy Lothlorian Audio, Video & TV 3 03-10-2014 09:56 PM
Microwave upgrade for Sport 16 Rich of SCal Stoves, Ovens & Microwaves 9 10-25-2012 11:55 AM
Roof crank up antenna wire goes where ??? dryenko Audio, Video & TV 10 01-17-2012 07:54 PM
Help with antenna location and setup dznf0g Phone, CB & Ham Radio 0 10-16-2011 08:46 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
