Old 12-06-2013, 09:32 PM   #15
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I have the Jack installed on my Bambi II. The wiring was new, as we did a total rehab on the wiring, but it works great. No issues with the aluminum. It just looks a bit weird on a 1964 trailer, but I likes me some TV at night!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-06-2013, 09:36 PM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I was going to mention this issue.
Somehow the Jack looks a little out of place on older trailers. Even on my PanAmerica I think it looks odd. I'm thinking of painting it with aluminum spray paint. Somehow I think it looks like an airspeed sensor on a jet!
Old 12-07-2013, 11:21 AM   #17
Becky B.'s Avatar
1964 17' Bambi II
I thought about spraying it with some aluminum paint, but my DH says the metal in the paint would probably interfere with the signal. Probably straight up grey would be better (not the silver that actually looks like polished aluminum). I might try it next spring.
Becky
1964 Bambi II
1988 Avion 32S
Old 12-07-2013, 12:40 PM   #18
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Slight if any RF loss. I have painted other batwings with rustoleum aluminum with null effect.
Old 12-07-2013, 02:11 PM   #19
Becky B.'s Avatar
1964 17' Bambi II
Good to know!!
Becky
1964 Bambi II
1988 Avion 32S
Old 12-09-2013, 09:36 AM   #20
2006 19' Safari SE
Hayes , Virginia
I purchased the OA8200-White, which comes with base, tower, antenna head, Wall Mount Power Injector, SureLock signal meter with enclosure base. With my particular set up, I have tried both the Surelock and the Wall Mount that came with trailer. Both connect directly to the antenna supplying the 12v that is required. I even tried bypassing trailer installed coax by connecting to the Wall Mount, taking the coax out the door and connecting to antenna. I tried both, connecting antenna on roof and running coax out about 20 feet from the trailer with proper connections, to no avail. I am able to get the signal strength, aluminated by 3 or 4 lights, by turning the antenna different directions. In addition I have tried connecting a purchased signal booster, scanning TV channels many times, to no avail.
I am at a lossssssssss. King Controls company, maker of Jack, is checking with their engineering department to see if the aluminum is the problem. I believe I answered that question by installing away from the trailer. If there is a solution or someone proves me wrong, let me know. I have misplaced my WEGA (for the WEGA Sony TV 19") remote control, using a regular Sony remote, and I am questioning if that could be the problem when scanning. Is scanning cable/satellite different than UHF/VHF? darn, I want an antenna that works.
mocus is offline   Reply With Quote
Old 12-09-2013, 10:01 AM   #21
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by kswelsh View Post
The crank-up gear has broken on our antennae and we are thinking about switching the whole unit out for a batwing antennae that doesn't need to be cranked up. Any thoughts on this. What brand is the best? How difficult is it to switch out the old antennae for a newer digital kind? Thanks!
This may be just stupid terminology stuff. But I have always thought of a "batwing" as the Winegard Sensar antenna all of which have to be cranked up. the Sensar comes with choice of amplified or unamplified heads. Additionally Winegard makes amplified or unamplified wall plates and other options for switchplates. Winegard also makes a "Wingman" add on which is supposed to better pick up on UHF (or is it VHF?) signals. The higher station numbers anyway. The Sensar/ "Batwing" is also a directional antenna, which Winegard at least told me in the day, does a better job of pulling in signals than a fixed boomerang type. That may have been more true in the old analog day than digital, but I'm not sure.
Old 12-09-2013, 04:04 PM   #22
2006 19' Safari SE
Hayes , Virginia
Some good stuff on this post....my latest encounter....Requested to talk with supervisor re problems I having with Jack via phone call. Supervisor called me back, had a very informative chat, and said company would send me a new antenna. He asked me to try antenna on another TV and I said I would do and would advise. Ya see, stepping up another notch to supervisor, and treating customer service reps with respect, works wonders. Will let ya know results.
Old 12-09-2013, 06:55 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sooooo... you guys getting the HDTV version?
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-09-2013, 07:07 PM   #24
2006 19' Safari SE
Hayes , Virginia
Yeap, the latest one advertised, OA8200.
Old 12-10-2013, 01:42 PM   #25
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sweeeeet! Thanky ya!
Channing
WBCCI# 30676
Old 12-10-2013, 02:02 PM   #26
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
RF is RF, there's no difference in antennas for a particular RF band between analog and digital (HDTV).
— David
DKB_SATX is online now   Reply With Quote
Old 12-10-2013, 02:11 PM   #27
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Yup... so many think there is really such a thing as a digital antenna.
I suppose.good marketing to an unknowing public will sell product!
A coat hanger is a good HDTV antenna!
Old 12-10-2013, 02:19 PM   #28
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That is in agreement with the Federal Communications Commission fact sheets:
Antennas and Digital Television | FCC.gov
For those who don't follow links, here's a pertinent extract from the fact sheet:
If your television received good quality reception on analog channels 2-51 with a broadcast antenna, it should be able to receive digital television (DTV) signals, including high definition television (HDTV) signals, with the same antenna. You do not need to purchase a "DTV antenna" or an “HDTV antenna” to receive DTV or HDTV signals; however, your antenna must be able to receive both VHF and UHF signals
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Winegard HA-0130 antenna... might buy Lothlorian Audio, Video & TV 3 03-10-2014 09:56 PM
Microwave upgrade for Sport 16 Rich of SCal Stoves, Ovens & Microwaves 9 10-25-2012 11:55 AM
Roof crank up antenna wire goes where ??? dryenko Audio, Video & TV 10 01-17-2012 07:54 PM
Help with antenna location and setup dznf0g Phone, CB & Ham Radio 0 10-16-2011 08:46 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
