Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 10-13-2016, 01:56 PM   #1
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
Television installation
I want to install my 55" Samsung in the living area of my Excella. The problem is its very heavy. My thought is to drill through to the exterior & bolt the mount with nuts & bolts. I know it's not ideal, but I really want my tv. Has anyone else mounted a tv this large & is there a better solution?
Thanks in advance for your insights.
Tampatomgirl
Tampatomgirl is offline   Reply With Quote
Old 10-13-2016, 02:16 PM   #2
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Is there a place where you can sit the TV? You can probably more easily bolt the base of the TV down instead of going through the exterior.
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 10-13-2016, 03:46 PM   #3
2021 16' Bambi
2021 22' Bambi
North Port , Florida
I would make a mount that bolts to the floor.
cliffcharb is offline   Reply With Quote
Old 10-14-2016, 06:29 AM   #4
Tampatomgirl
1990 34' Excella
I don't want it to be stationary & there will be a flat panel electric fireplace below it, so I can't put it on a stand. I was hoping someone knew of a better way to secure 45 lbs to the interior wall.
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 4 07-14-2020 01:50 PM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Television Program Inland RV Center, In Airstream "In the News" 18 03-31-2013 11:39 PM
My television antenna plug on 77 international wayne.yl Audio, Video & TV 6 12-12-2003 03:47 PM
television - looking for great airstream couple sunny181957 Airstream Motorhome Forums 0 08-07-2003 10:27 AM
