Old 02-11-2019, 06:41 AM   #15
Providence , Rhode Island
Originally Posted by Myelfself View Post
I sure wish somebody, anybody made an RV head unit with a blue ray player
It's coming.........just won't be cheap:
kittmaster is offline   Reply With Quote
Old 02-18-2019, 12:29 PM   #16
2014 22' FB Sport
West Valley City , Utah
Easy and cheap.
I have a 2014 22fb. The DVD seems to have issues. However a cheap alternative to changing out all of your hardware so you can get better sound out of the TV ( I know the original TV leaves a lot to be desired) is to simply run a mini patch cable from the headphone jack of the TV to the Auxiliary In jack on the stereo. It will put out plenty of sound for that small space and only will cost maybe $10.
Most of my movies are on a hard drive or my Surface can stream whatever I need. I just hook the Surface into an HDMI port via an adaptor. It isnít as pretty but it is effective.
Rhuffer2 is offline   Reply With Quote
Old 02-23-2019, 10:33 AM   #17
2016 28' Flying Cloud
Brandenburg , Kentucky
40 Inch Samsung + Bose
Outstanding picture and sound with Blu-tooth
Tsunami-v2 is offline   Reply With Quote
Old 02-23-2019, 10:39 AM   #18
Date on that video is 2011, nothing yet from Sony!
Old 02-27-2019, 09:14 PM   #19
1970 27' Overlander
Attica , Michigan
The deeper I get into this the more problems I see. I was just looking at subs and amps and now I'm worried about power consumption. I'd like to be able to keep a fridge running on solar most of the summer, while being able to listen to the radio at least on weekends when trailer is parked out at our vacant land. Just ordered a solar/battery package from northern Arizona wind and solar. 640 watts of panels, 2000 watt inverter charger and 2 battleborn batteries, plus all the connections and such. Just need an electrical engineer to figure out power consumption lol.
Myelfself is offline   Reply With Quote
Old 03-09-2019, 08:07 AM   #20
Save Power
I removed the sub from my 28' AS. I found it acoustically a waste and it allowed me to use the radio with out consuming power while boon docking. I'm in the decision process phase of selecting a double DIN unit. Hold up is deciding touch screen type, capacitance or resistive.
Old 03-09-2019, 08:26 AM   #21
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
That is because everybody is too busy texting to have time to watch a movie while driving.
Mattirs is offline   Reply With Quote
Old 03-09-2019, 08:28 AM   #22
Mattirs's Avatar
Guess everybody is too busy texting now to be watching a movie while driving.
(Oops didn't see the first one post until after I retyped this one)
Old 03-10-2019, 02:47 PM   #23
2019 22' Sport
Quartzsite , Arizona
Howdy!
I just finished installing a simple but much nicer unit and speakers.
A Kenwood DDX395 with a pair of JBL GTO629's
Not an audiophile set by any means but I'm not convinced much could be done with acoustics on a small scale. This whole set up costs ~$275.
It seems the speakers were about as good as it gets till you get much more serious with remote components; these were plug and play perfect fit.
The head unit does more than I want or need and I got it specifically for a little more sonic punch (which it does!) and a simpler more reliable dvd player (which it is!). I had to build a box for it as it's the larger LED screen version built for a car dash. But wired in ~10 minutes! There does not appear to be an old fashioned in dash like the stock player that would be any better so if you want to upgrade you'll need to consider a new box.
It seems for more money you get marginally improved sound and more integration with automobiles and other bells and whistles that don't seem needed. It has some integration with Sirius but I don't have such subscriptions.
Half volume is more than enough so more watts a waste.
So far quite happy with the sound and ease of installation!
R44
Rounder44 is offline   Reply With Quote
Old 03-13-2019, 11:03 AM   #24
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Originally Posted by Rounder44 View Post
Howdy!
R44
Throw some photos up of the finished product
Cispook is offline   Reply With Quote
Old 03-14-2019, 01:07 PM   #25
Hopeful
Just talked, in person, to a Sony car stereo dealer, who informed me that he's going to a regional dealers meeting on the soon to be released products. He said that there has been talk of a 12VDC double-DIN AM/FM (digital) Blu-Ray/CD/DVD player. He's going to call me with an update. Fingers crossed!
Old 03-15-2019, 05:32 PM   #26
2019 22' Sport
I haven't quite finished it yet; probably clad in white formica and have to get a hole saw for the USB outlet but basic install done.
Speakers are much more robust with large magnets but fit fine with the stock spacer rings. I drilled out the spacer rings screw holes to allow flush set bigger sheet metal screws and then attached the new speakers to the spacers and into aluminum. The speakers are heavy enough, maybe twice as much as the stock, and need to be securely attached.
Two trips and some bumpy roads and holding tight!
ID:	335788   Click image for larger version
Old 03-16-2019, 11:18 PM   #27
Cispook's Avatar
Chillicothe , Ohio
Nice work.
2005 Safari Electric Jack & Stereo/DVD Stopped Working 2ColliesCan Electrical - Systems, Generators, Batteries & Solar 0 06-24-2018 07:08 PM
Stereo upgrade etc... Amy air Our Community 15 11-24-2017 12:17 PM
Upgrade for the 1979 vintage stereo speakers blickcd Audio, Video & TV 2 11-22-2017 10:27 PM
Need stereo upgrade advice??? samiam8888 Audio, Video & TV 16 10-18-2012 10:16 PM
