Old 09-08-2017, 10:18 AM   #1
RxGuy's Avatar
2010 27' FB International
Bois Blanc Island , Michigan
Stainless steel exterior receptacle covers with exposed screws?
I have been looking for a cover for the external electrical outlet in SS.
Looking online, I found the one in the bottom photo, a Pass and Seymour WPH26, and had the local electrical supply order it:
What came in was the top photo, a Pass and Seymour WPH26 with the screw holes exposed.
Anyone using a cover similar to the top with the exposed screw holes? If you have, are there any issues with water intrusion because of the screw holes?
I do realize that these covers are not "weather proof", but they are still used externally.
Thanks...
RxGuy is offline   Reply With Quote
Old 09-08-2017, 12:10 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have concerns about the screw holes seal the screws with dumb dumb before tightening them down or place small O rings in the screws.
I think you are tilting at wind mills being concerned about a leak at the screws.
2004 Excursion 4x4
Stainless steel exterior receptacle covers Gneiss Guy Electronics & Connectivity 18 10-02-2016 06:04 PM
Stainless steel wheel covers. gloran Airstream Classifieds 0 04-08-2015 04:39 PM
Stainless steel hub dust covers adonh Wheels, Hubs & Bearings 4 11-17-2011 04:18 PM
Stainless steel screws instead of rivets? Lothlorian Ribs, Skins & Rivets 33 03-23-2011 12:22 AM
steel or stainles steel screws remcolent Ribs, Skins & Rivets 11 03-30-2004 07:54 AM
