Old 09-22-2018, 02:15 PM   #1
2019 25' International
Washington , Washington, D.C.
Solar Panels with Exposed Cords + a 'what is this?"
I climbed a ladder to check the top of my Airstream for the first time last week and have three questions (photos attached):
1) The two plug-in cords that run from the box to the solar panels look like what is shown in my Owner's Manual. However, do I need to be concerned that the cords are, well, just lying there?
2) Should I unplug the two cords from the receptacle and use the plug protectors attached to the plugs (can be seen in photos) to keep rain/snow out over the winter?
3) What are two foot-long, elongated shields on side of air conditioner?
Thanks so much - I continue to learn so much from this very helpful community.
ID:	323321   Click image for larger version
ID:	323323   Click image for larger version
PatLee is offline   Reply With Quote
Old 09-22-2018, 02:35 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I can't comment on the Factory solar install except to say... it's a Factory solar install.
3m cord clips could help tighten & secure them.👍 Better if you could find them with permanent 3m adhesive.
The shields are to deflect air away from the fridge vent while towing.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 09-22-2018, 03:41 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
The solar wires are fine... not the neatest / cleanest install but having them exposed is fine they are rated for outdoor use. No need to disconnect in the winter either - those or SAE connectors designed for outdoor use.
Again, not as neat and tidy as using a sealed junction box but it does the job and will give you years of trouble free use.
wulfraat is offline   Reply With Quote
Old 09-24-2018, 12:38 PM   #4
Thanks for the reassuring information.
Old 10-09-2018, 11:21 AM   #5
cballard's Avatar
Thank you for asking this question - I've always wondered about this myself!
cballard is offline   Reply With Quote
Mounting options for "wide" solar panels with overhang. larry9000 Generators & Solar Power 4 10-15-2017 08:32 AM
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Exposed battery terminals nickcrowhurst Batteries, Univolts, Converters & Inverters 7 12-20-2008 01:51 PM
