Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 09-22-2018, 02:15 PM   #1
2019 25' International
Washington , Washington, D.C.
Solar Panels with Exposed Cords + a 'what is this?"
I climbed a ladder to check the top of my Airstream for the first time last week and have three questions (photos attached):
1) The two plug-in cords that run from the box to the solar panels look like what is shown in my Owner's Manual. However, do I need to be concerned that the cords are, well, just lying there?
2) Should I unplug the two cords from the receptacle and use the plug protectors attached to the plugs (can be seen in photos) to keep rain/snow out over the winter?
3) What are two foot-long, elongated shields on side of air conditioner?
Thanks so much - I continue to learn so much from this very helpful community.
ID:	323321   Click image for larger version
ID:	323323   Click image for larger version
PatLee is offline   Reply With Quote
Old 09-22-2018, 02:35 PM   #2
"Cloudsplitter"
I can't comment on the Factory solar install except to say... it's a Factory solar install.
3m cord clips could help tighten & secure them.👍 Better if you could find them with permanent 3m adhesive.
The shields are to deflect air away from the fridge vent while towing.
Old 09-22-2018, 03:41 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
The solar wires are fine... not the neatest / cleanest install but having them exposed is fine they are rated for outdoor use. No need to disconnect in the winter either - those or SAE connectors designed for outdoor use.
Again, not as neat and tidy as using a sealed junction box but it does the job and will give you years of trouble free use.
wulfraat is offline   Reply With Quote
Old 09-24-2018, 12:38 PM   #4
Thanks for the reassuring information.
Old 10-09-2018, 11:21 AM   #5
cballard's Avatar
Thank you for asking this question - I've always wondered about this myself!
cballard is offline   Reply With Quote
Mounting options for "wide" solar panels with overhang. larry9000 Generators & Solar Power 4 10-15-2017 08:32 AM
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Exposed battery terminals nickcrowhurst Batteries, Univolts, Converters & Inverters 7 12-20-2008 01:51 PM
