Join Airstream Forums Today
Old 02-19-2012, 03:20 PM   #1
2012 30' Classic
Bigfork , Montana
Solar Controller
Hope I haven't posted this twice, but it doesn't seem to have showed up. At any rate...
It is bright and sunny here in California’s Borrego Springs, and all of a sudden the two aftermarket inverters in our Airstream stopped working. We charge our system with four large solar panels producing an equivalent of about 600 watts going into our system. We control the flow of energy to our batters and subsequently to our inverters using a Zamp Solar Charge Controller. Once when the Controller showed a spike to 16 volts I wrote the manufacturer and the representative said it was a surface charge and not to worry, because simultaneously the Controller showed a charge of but 0.2 solar amps/hour.
When the inverters stopped working I again thought high voltage and sure enough, it was reading 16-plus. We turned everything off and about an hour later again tried the inverters, and all was well.
Could my problems with the inverters have resulted from a spike in volts to the inverters?
Can someone tell me what’s going on and if we need to worry?
Thank you.
Bert
Bert Gildart is offline   Reply With Quote
Solar Power Quest Mr & Mrs S Boondocking 58 03-02-2012 02:03 PM
Connecting Brake Controller MKT playared Brakes & Brake Controllers 1 02-19-2012 05:54 PM
Solar Controller Bert Gildart Generators & Solar Power 2 02-19-2012 03:51 PM
Solar panel display blinking HootMon-Frau Generators & Solar Power 0 02-18-2012 10:26 AM
Brake controller on a F-150 King Ranch Lfemat Tow Vehicles 5 02-17-2012 09:08 PM
