Old 06-13-2012, 05:53 PM   #1
judybug's Avatar
2004 25' Safari
san antonio , Texas
Solar Charger For Batteries
I'm needing information on how to hook up a solar trickle charger to safari batteries. What goes to what? Red to whatever. Also only two wires came with the solar contraption and with two vise connections. Two batteries with safari. Help
judybug is offline   Reply With Quote
Old 06-13-2012, 06:01 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Pictures? would help.
Michelle TAC MT-0
Sarah, Snowball
Old 06-13-2012, 06:24 PM   #3
Mike91208's Avatar
2009 27' FB International
LA LA Land... , California
If it works like mine, connect the positive wire to the positive pole on one battery and the negative wire to the negative pole on the other battery.
Mike91208 is offline   Reply With Quote
Old 06-13-2012, 06:38 PM   #4
2005 19' Safari
GLENDALE , AZ
Important question: Do you have two 12-volt batteries connected in parallel, or two six-volt batteries connected in series? A photo of your battery box and cables would help.
Old 06-14-2012, 04:46 PM   #5
judybug's Avatar
2004 25' Safari
san antonio , Texas
Pics of Batteries
Well, I hope there is a picture attached to this. I'm puzzled over how to attach pics.
Old 06-14-2012, 06:59 PM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
As Mike said above -
The POS of the solar panel goes to one of the POS terminals on one of your batteries...
The NEG wire of the solar panel goes to the NEG terminal of the OTHER battery - this allows for an 'even' charge to both batteries & tends to even out the small resistance of the connections...
If your solar panel does not use a charge controller, make sure you have a blocking diode in the wiring circuit between the panel and the battery - this will prevent any discharging of the batteries when there is no sunlight - IE, at night!
Ray & Pat; Morada, CA
