Old 08-14-2019, 06:41 PM   #1
2019 19' Flying Cloud
Sewickley , Pennsylvania
SiriusXM Install
Here’s how I incorporated XM into our 2019 Airstream Flying Cloud 19CB.
It comes with a Clarion radio, Model M303 M508, which is XM READY.
It does not come with a factory installed XM antenna, nor is one offered, and I am loathe to drill any holes into the trailer.
PARTS (Prices are delivered)
XM Module: SiriusXM SXV300v1 Connect Vehicle Tuner $38.51 Amazon
A variety of small zip ties
Sticky Velcro Strips Home Depot
XM Antenna: SiriusXM SXHA1 Outdoor Home Antenna $45.31 Walmart Online
Impact Light Stand IMLS6B $29.52 bhphotovideo.com
4 Nylon Lock Nuts Home Depot
10’ RG6 Coax Cable
F-Type Female to F-Type Male Push-on Right Angle AdapterSKU 185 $7.90 showmecables.com
Rifle case: Allen Cottonwood Model 624-46 $35.26 Local shop
Solution:
Open the bulkhead compartment where the DVD player lives. Ease out the DVD player and disconnect the cables. It’s velcroed in place. Remove the 4 screws on the lower left hand edge of the cover that houses the DVD player. Don't try to remove just the 2 screws that look like they secure the “mouse hole” access. They don’t. That little half-moon piece is actually secured to the DVD shelf from the inside. Once all 4 screws are out, the DVD housing can be removed. It takes a little fussing to angle it out and then get it back in. Perhaps shoot a brief video to remind yourself how you did it. Could save some reinstallation grief later.
You’ll now have access to a rat’s nest of cables shoved behind the Clarion radio. One cable is obviously coax. Free it up. It is RG6 and runs to the antenna connection port on the outside of the trailer. Next, pull up the installation diagram for the Clarion radio to see which connector is to be used for the XM module. Free it up. All of the other wiring is best left in the nest.
The XM module comes with an adapter that allows the RG6 to be connected to it. Fish the Clarion cable and the RG6 adapter through the cable hole in the shelf. Connect both to the XM module. I then used 2 strips of sticky-back Velcro to secure the module to the top side of the shelf. Put the loops on the shelf and the hooks on the module. I also used some micro zip ties to dress up the cables hidden under the DVD shelf.
Follow your video to get the shelf back into position and secure with the 4 screws. Next, the DVD Player can be put back. Best if you have some small hands available to get the cables back onto the DVD.
Okay, so that part of the project is done. You can turn on the Clarion, punch up XM and go to channel 0 to get the unit ID. It’s also on the box that it came in. You’ll need that to activate the unit.
The antenna.
I ordered a lightweight, compact photographer’s light stand to mount the XM antenna on. The accompanying picture is fairly self-explanatory. I only used the base pole of the stand and stored away the extensions. The extra height was unnecessary and could allow it to be tipped over.
The U-clamps that come with the antenna are too long and the lock nuts that come with it, I suspect, could loosen up over time. As such, I added a ¼-20 nylon lock nut behind each. Used a bolt cutter to trim the remaining threads, and filed down the sharp remnants.
10 feet of RG6 is plenty long enough to allow the antenna to be positioned facing the southern sky, no matter the orientation of the trailer, but not so long as to be a hazard. Also, contrary to the picture, I ended up turning the antenna 180 degrees relative to its original mount on the arm. This allowed for a more compact/streamlined system. Makes it easier to store and less susceptible to being broken off.
Connecting the antenna.
The antenna ports on the side of the trailer go 2 places. The female connector on the left goes to the TV. The connector on the right goes to the bulkhead/XM. That’s where you hookup. You can connect the RG6 directly, but sometimes a pain getting the threads to align. Also, to reduce downward pressure on the connector and to make for an easier connection, I added the above mentioned push-on right angle adapter.
Storing the antenna.
The system is just a little too large in diameter to fit in a 4” tube such as PVC/ABS. So it won’t fit in the sewer hose storage tube on the underside of the trailer. Nor did I want it bouncing around in there. I could not find a 5” shipping tube. So, what to do?
Found a short, soft-sided rifle case at a local gun shop that was perfect.
Good luck!
ID:	349422   Click image for larger version
ID:	349426   Click image for larger version
mohrmh is offline   Reply With Quote
Old 08-14-2019, 07:05 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Everything similar to what you did, but I did drill through the roof.
Here is my installation. http://www.airforums.com/forums/f48/...ml#post2256692
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 08-14-2019, 07:38 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Now that you've done all that work, you could either run the wire for the antenna up to and through the front roof vent, or over and up through the fridge vent (if your trailer has a roof fridge vent).
2016FC23D SiriusXM radio? Atsushi 2016 - Current Flying Cloud 2 05-09-2019 05:37 PM
Poor reception from SiriusXM Boxster1971 Sprinter and B-van Forum 17 11-20-2014 10:56 AM
SiriusXM Service cost UKDUDE Sprinter and B-van Forum 12 09-03-2013 06:08 AM
Satellite Radio ( SiriusXM) RMB Electronics & Connectivity 1 09-18-2011 01:44 PM
