Old 03-31-2014, 09:32 AM   #1
2005 28' International CCD
Pittsburgh , Pennsylvania
Sharp Microwave Problem
A few days ago the microwave portion of our Sharp R820bk Carousel convection oven ceased working.
The convection portion still works.
To put it on the local repair man's bench is $45. a new one is $280.
I opened the back and found the mounts of a cooling fan had shaken loose and fixed that -- but it still doesn't work on microwave.
I hate to discard something that may still have value if I can fix what is broke.
I talked to Sharp, two Airstream dealers, and the local repair shop and none of them had ever heard of such a problem. Could the magnetron have gone bad?
The unit is 9 years old.
Any ideas?
Bilo Hak is offline   Reply With Quote
Old 03-31-2014, 09:49 AM   #2
1998 30' Excella 1000
Livingston , Texas
My magnetron went out after 5 years. The repair guy offered to replace with a used unit, at a low cost, but with no warranty. It has lasted 9 years of fulltime use. Knock on wood.
But to your issue. The repair guy gave me two tips, if it stopped working. One was a fuse. The other was a small screw on the side of the case, I can't remember where. It is a safety device that prevents the magnetron from operating if you have opened up the case, but could vibrate out part way and shut down the magnetron. Try looking for it.
Siegmann is offline   Reply With Quote
Old 03-31-2014, 09:51 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
At nine years old, it's about due for replacement anyway. But if you really want to tackle it, a couple of troubleshooting questions…
1 - Does the turntable turn?
2 - Does it make a buzzing noise or just sit there looking back at you?
The two most common problems are the internal fuse and the door latch. But if the convection oven portion still works, and the turntable still turns, chances are the fuse and door latch are both still working fine.
If you hear a buzzing noise, the most common problems are the power diode, the capacitor, or the magnetron. The capacitor in particular can shock the living daylights out of you, but all three parts are replaceable. I don't know whether you'll save any money replacing any or all of those compared to buying a new machine.
You might consult this webpage for instructions on how to replace a given component…
https://www.partselect.com/microwave+repair+repair.htm
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-31-2014, 10:57 AM   #4
Thanks for the knowledgeable response.
In answer to your questions: everything works as normal except the water I put in the oven does not get warm on microwave mode. The oven warns in convection mode.
As mentioned in my first post, I decided to dig into the unit and discovered the rear ventilation fan motor had worked loose and the fan was jammed. I thought I had it made. I remounted the fan motor, put it back together, and nothing changed.
The sound of the unit changed when this malady occurred. It got louder. I just hate to dispose of the entire unit if it can be fixed. I see a new magnetron can be got for $63.
Old 03-31-2014, 11:09 AM   #5
The web site you directed me to does not support the model I have. Thanks anyway.
Old 03-31-2014, 11:24 AM   #6
General repair instructions on how to replace a magnetron, power diode, or capacitor should hopefully still be useful, though.
WBCCI #1105
TAC LA-4
Old 03-31-2014, 11:28 AM   #7
I can't get the control panel off. But I can pull it away from the unit -- a couple of mounting tabs have broken but the one on the upper left is good and the control panel will not lift up on that side due to interference with the outer case of the unit.
I can see the fuse and the glass is all cloudy. Does that mean anything?
'86 345 MH Sharp Microwave/Convection Oven Jim Tyrney Airstream Motorhome Forums 2 02-13-2018 10:58 PM
Sharp Carousel II Microwave manual wandering Stoves, Ovens & Microwaves 4 01-01-2008 08:06 PM
Sharp microwave / convection pjude General Motorhome Topics 7 11-09-2007 05:15 PM
Sharp microwave convection oven Larry C Stoves, Ovens & Microwaves 2 05-17-2007 01:59 PM
Sharp Convection/Microwave failure myoung Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-01-2006 05:53 PM
