Old 10-10-2015, 07:03 PM   #1
2016 25' Flying Cloud
Black Diamond , Washington
satellite tv hookup
Need help understanding installation of satellite tv. I have a2016 Flying Cloud 25fb. I want to install a weingard or king stand alone system. My outside connections show cable and satellite coax. Do I simply attach coax to the satellite coax outside and done? Ot is some sort of receiver needed in the trailer? If so, how is that attached... How does the bluray player come into play? Any help for this novice appreciated
toothpull is offline   Reply With Quote
Old 10-10-2015, 07:43 PM   #2
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
You will need a receiver- either Dish or Direct Tv. If you have either one at your home, and one of your receivers are not part of a 'Genie network (Direct TV unit), you can simply take it with you from your house. That is what we do. We have Direct TV, and have the Genie system for all rooms except one, where we have a stand alone DVR unit. It works great! Our King dome unit is attached on the roof, so it is direct wired.
danjoe91 is offline   Reply With Quote
Old 10-10-2015, 07:44 PM   #3
2016 30' Classic
Erie , Colorado
Connect to the SAT connection. Inside you will need to install a SAT receiver and connect the incoming cable labeled SAT which is usually tucked behind the DVD player. Might take a bit of work to find it. You will also need an additional HDMI switching unit unless your FC has another input for connecting to the SAT receiver. Or you can simply unplug from the DVD player and into the SAT receiver.
2015 Classic
2015 GMC Sierra 2500HD Duramax
ghaynes755 is offline   Reply With Quote
Old 10-11-2015, 08:20 PM   #4
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
Ditto on what Gary said. I had to remove the DVD player to find the Sat labeled cable. After that, I added a 2x4 HDMI splitter where I have both DVD and Sat available without changing inputs all of the time plus I can split usage of the TV's from front to rear. In other words, use Sat on one of the TV's and DVD on another or any combination of over air TV, Sat, DVD as desired. We use a portable tailgater system and it works well. Good luck.
silverlabs is offline   Reply With Quote
Old 12-13-2015, 06:47 PM   #5
Mrjkq's Avatar
Venice , Florida
What timing,TODAY I got mine connected & running. The box with the blue ray in it has three screws to remove (they are covered by white tabs) once done lift the box ( leave the blue ray alone) & you'll find the coax cable just laying in there in plain sight. As mentioned in a previous post you must replace the switcher/splitter supplied by AS with a 2x2 s/s box. Feed the coax & HDMI cable out the left side of the blue ray box, just remove the black tab covering the hole, attach coax & HDMI to back of dish receiver box, plug in & you're done.
I have step by step instructions sent from Airstream, if you PM me your email I'll forward to you.
Venice, FL
2016 FC 25RTB
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-10-2016, 01:52 PM   #6
2015 25' FB Flying Cloud
Reno , Nevada
Another question. I have a 2015 25FB with the Sirus/XM ready radio. How do I find the code for the radio to activate Sirus/XM and, do I have to pay an additional fee to activate this radio. I already have Sirus in my truck.
Mike25FB is offline   Reply With Quote
Old 01-19-2016, 08:53 AM   #7
AStreamNerds's Avatar
Manassas , Virginia
You will have to have another subscription for the AS and Sirius/XM ready just means you will need to still purchase a Sirius/XM tuner for it which is why you cannot find the code.
You Tube Channel "Airstream Nerds":
Find Us on Facebook:
AStreamNerds is offline   Reply With Quote
Old 08-10-2016, 08:34 AM   #8
Picinisco's Avatar
1977 Argosy 24
Gilbert , Arizona
Did you install the King Dome yourself?
1977 24ft Argosy - sold.
Picinisco is offline   Reply With Quote
Old 08-11-2016, 10:13 AM   #9
danjoe91's Avatar
1985 32' Excella
Images: 16
We bought our rig with the Kingdome already installed. The couple we bought it from used to run both cables from the receiver in the trailer to the cab of the truck with a tv on her lap while they were driving so they would not miss any re-runs of The Three Stooges!
Satellite Hookup - What's needed - 2015 Flying Cloud PSU1981 Computers, Internet & Satellite 2 05-31-2015 07:31 AM
Satellite hookup for 2015 27FB Cloud PSU1981 Computers, Internet & Satellite 0 05-25-2015 02:16 PM
Outside water hookup question. 68 Suburban Fresh Water Systems 6 10-05-2013 02:25 PM
Satellite TV Hookup KathleenB Computers, Internet & Satellite 5 01-03-2013 06:23 PM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
