Old 08-04-2012, 08:09 PM   #1
TNB
2011 30' International
Lebanon , New Jersey
Satellite Installation
We just purchased a 2012 serenity 30 and went to visit at the dealer today. The pickup is next Saturday. They are installing satellite and are not finished but we were surprised to see the boxes mounted directly on the walls. There must be a better way? Does anyone have experience or advice on this? Thanks!
TNB is offline   Reply With Quote
Old 08-04-2012, 08:14 PM   #2
Ottawa , ON
By "boxes" do I assume correctly that you are referring to the electronics, the satellite tuner/decoder and what, a DVD player?
Old 08-04-2012, 08:21 PM   #3
TNB
The DVD is I'n the overhead at the couch end of the airstream. There is a converter box right next to the tv in the galley area and one I'n the bedroom. They literally have the box flat on the wall.
Old 08-04-2012, 08:29 PM   #4
Ottawa , ON
OK, thanks for explaining that. Oh, and welcome to the Forums, by the way!
So, where would you rather have them install the boxes?
Old 08-04-2012, 08:41 PM   #5
TNB
My thoughts were that they would be where the DVD is out of sight.
Old 08-04-2012, 09:06 PM   #6
2012 28' Flying Cloud
Ozark , Missouri
despite the $800+ for the second tv (which i was told was due to the wiring required) the wiring for a satellite box was miserably inconvenient - the connection was at the dinette table. This put the box on the table, although some had suggested connecting it to the underside the table. in addition, all connections were made with coax cable rather than HDMI prevending the high definition reception. Miserable design.
emalt is offline   Reply With Quote
Old 08-04-2012, 11:33 PM   #7
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Speak up BEFORE they do something you will not like!! My AV controls, etc. are NOT in plain view. However, your unit may not have a easy solution.
Urbanologist is offline   Reply With Quote
Old 08-04-2012, 11:37 PM   #8
xo1rider's Avatar
2012 27' FB International
Fremont , California
I have a pretty new satellite installation and the control box and all the cables etc. are on the shelf in the closet. I've got the satellite control box, a DVR and a HDMI splitter all sitting on the shelf in the closet. All of the coax cables from the dish terminate in there as well as both HDMI cables for the TVs. I purchased a RF remote from Direct TV and the entire installation is seamless as well as out of site.
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 08-05-2012, 04:59 AM   #9
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
X01,
Interested in your install. Is your dish on the roof? If so did they run new wires from the dish to the closet, and new HDMI wires from the closet to both televisions? If so it sounds much tidier than using the existing coax connections provided by AS.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 08-05-2012, 07:44 AM   #10
TNB
Thank you. That sounds like the right design and says that the wiring from the room can find it's way to the back of the airstream. I will call them tomorrow! Thanks
Old 08-05-2012, 07:46 AM   #11
TNB
Thank you. The clarity of questions helped with validating this is possible
Old 08-05-2012, 07:55 AM   #12
xo1rider's Avatar
Originally Posted by DMT View Post
X01,
I'll try to answer but understand that I was not there when it was done.
The dish is on the roof and collapses when not in use, it sort of folds down to lie flat (well mostly flat). In the closet there are four coax cables, three coming from the dish and one that (in my opinion) is not needed. I use two of the cables for my DVR, the third I guess would be used if I wanted two receivers and the fourth for some reason just runs into the living room and comes out behind the TV. I still don't know why or what I would do with it.
There is a control box by Winegard in the closet that uses 110v. That box has the control that raises and lowers the dish, there's a LCD panel showing which satellites are being used (three of them). Two HDMI cables from that box, one for the front TV and one for the bedroom TV. I use a small HDMI splitter, in my installation we can watch either TV but of course both TVs will have the same channel. You'd need two receivers if you wanted different programs.
I can't tell you much about routing of cables other than when I look in the panel where the water pump is I see a rats nest of coax cables. I see no evidence of the installation other than in the closet and the terminus of the HDMI cables attached to both TVs. In general the installation is seamless. Using the source selector on the TV I can choose inputs from the dish, digital antenna, cable TV input or DVD.
The dealer who installed it is Toscano RV in Los Banos, CA. They use an outside audio/visual guy for all their electronics. I suspect if you phone them you could get more technical details on cable routing etc...
Swami Beyondananda
Our travel log
Old 08-05-2012, 08:29 AM   #13
Ottawa , ON
Glad you got the answer you needed.
Could they have run four cables since an HD (hi def) signal requires two cables?
Personally, I would not accept a set-up that requires both sets to watch the same channel. To me, that defeats part of the purpose in having two TVs.
Old 08-05-2012, 08:50 AM   #14
DMT
DMT's Avatar
X01,
That's what I thought. You still have the original digital antenna that was stock on your 27FB and also a stand alone satellite dish? If so it probably means they put a new hole in the skin to get the coax from the dish to the receiver. Is this hole visible or is it under the mount for the dish?
