Old 01-14-2014, 08:06 PM   #1
jump's Avatar
2013 30' International
lubbock , Texas
Samsung tv goes on & off & on & etc
2013 30' International Signature ... The samsung tv is going off/on/off/on ... I've un plugged/re plugged ... Checked breaker switch ... And I'm completely baffled.
If anyone has experienced this, I'd appreciate it if you'd let me know how you solved the issue.
jump is offline   Reply With Quote
Old 01-14-2014, 08:12 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is it on, then turns off? Then you turn it on, and it turns off?
Have you eliminated the possibility of a neighbor pointing his remote at your trailer, and playing games?
Do you have any kind of surge protector on the tv or trailer?
Has it worked before, and is just now doing this?
Old 01-14-2014, 08:13 PM   #3
Well Preserved
1993 21' Sovereign
And are you sure you aren't sitting on one of the remotes?
Old 01-14-2014, 08:24 PM   #4
jump's Avatar
lubbock , Texas
It has happened at two different rv parks now but outside interference? Not sure one way or another.
It turns off & on repeatedly on its own.
No, we are not sitting on the remote. Yes, I'm sure.
Old 01-14-2014, 09:16 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Never had it happen with a Samsung, but I once had a Sharp Aquos that did the same thing, at home. Turns out the infrared receiver in the television was on the fritz. There was no fix except to replace the television.
It's not likely to be interference from other RVs. An Airstream's aluminum skin will not allow a television remote's signal to pass through, unless they're standing right outside your window and aiming their own Samsung remote at your television through the glass. Which would be kind of a creepy thing for them to do, but I suppose it is remotely (ahem!) possible…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-14-2014, 09:53 PM   #6
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Our Samsung also turned off and on and the fix for our tv was the black frame on the edge was pulled away and when I snapped it back on it would turn on again. It took me contacting the airstream factory to have my selling dealer replace it under warranty because they wouldn't. It was replaced and we haven't had any problem since.
subfan1 is offline   Reply With Quote
Old 01-14-2014, 10:58 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
Our remotes are IR (not RF); so there is little chance of an extraneous remote outside of your AS triggering your set. Have your dealer let it run out of the AS and inside the shop and replace when it still acts up...before the electronics warranty expires.
If the outlet is not shared with solar (or use a multi plug), plug in a lamp or radio to see if it also cycles on/off with the TV as well.
Old 01-14-2014, 11:55 PM   #8
Hephzibah , Georgia
What you describe sounds like an issue with the power supply in the TV. I dealt with this on a 46 inch Samsung tv after it was damaged by a lightning strike. New power supply fixed it.
nti06 is offline   Reply With Quote
Old 01-15-2014, 05:46 AM   #9
Well Preserved
1993 21' Sovereign
Just ruling out the obvious. Yes, an Airstream came in to our shop with the tv turning on and off, and changing channels on its own. The remote was stuck in the dinette cushions, so it can happen.
Old 01-15-2014, 07:44 AM   #10
jump's Avatar
lubbock , Texas
If it is the power supply, wouldn't other things be affected also?
I have not noticed any other items acting up.
Old 01-15-2014, 02:53 PM   #11
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Do you have 2 sets? Our remote controls will turn on and off and change channels on both sets at the same time. You have to be careful when you aim, the ir signal will bounce off the interior.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 01-15-2014, 03:06 PM   #12
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
my samsung LCD 46 inch had a similar issue with the power supply...you would just hear it cycle "tick, tick....tick...tick...tick" trying to cut on...but in my case it would not....there were various class action lawsuits with samsung about this and I think other TV's regarding very cheapy capacitors used in the power supply....samsung agreed to repair it and they did and no problems since.
I would call the manufacturer...
PharmGeek is offline   Reply With Quote
Old 01-15-2014, 08:23 PM   #13
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Que the spooky music!
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 01-15-2014, 08:37 PM   #14
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Our Samsung TV on our Bambi did this after about 6 months. Airstream agreed to replace it after I verified that it wasn't a problem with the 120v supply. As Airstream modifies the TV with RCA line out's and did not have one for us right away, I decided to remove the rear cover and just have a look.
After seeing nothing, I reattached the cover and from that moment everything worked fine.
We got the replacement TV a few weeks later.
Are you still under warranty?
Bruce
Bruce B is offline   Reply With Quote
