Old 07-15-2012, 08:34 PM   #1
1989 29' Excella
greenville , South Carolina
Running lights
I saw a fellow air streamer in a park we were staying with his running lights on in the evening at his site without hook up to car-is this an easy thing to do to your trailer or does it involve complicated wiring. We now have an 08 international 28 ccd.
muletuff is offline   Reply With Quote
Old 07-15-2012, 08:42 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes
put a jumper wire between the battery terminal and the running lights on your umbilical cord.
I you really want some fun get a 2 prong directional flasher and use it. The position of the pins on the flasher are in the right relationship.
2004 Excursion 4x4
Old 09-23-2012, 08:28 PM   #3
1989 29' Excella
Running lights
So do you cut in with a regular on/off type switch? Please forgive my electrical ignorance. Thanks again.
Old 09-23-2012, 08:47 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Some will provide you with a do-it-yourself way to do this by connecting two of the connections of your umbilical cord...some include a fuse, some don't... and some actually build a device that does this. Below are some instructions from "Moosetags" that I kept from a post on the forums.
We use a "store-bought" device called a "Flash Cube" but I don't think they are made any longer. Pity. We club the umbilical cord into it and it allows all the running lights to be on as well as the tail lights ... or all the running lights with the tail lights flashing. We only use this is we have shore power, though, when shore power can provide the juice rather than our batteries. We call them our "Party Lights."
Name:	How to wire for Running Lights On.png
ID:	168916   Click image for larger version
TB & Greg and Abbey Schnauzer
#3954
Old 09-23-2012, 09:01 PM   #5
HowieE's Avatar
Images: 12
While looking at the face of your umbilical cord
Electrical Tips
Put a piece of #12 wire between the connection at 11 and 1 o-clock. You can also use a fuse holder from Radio Shack with a 15 amp fuse.
This will cause the parking light to light as long as the wire is in place.
For fun put a 2 prong flasher in there and the lights will flash. Not something you want to leave on all night, as it will drive the neighbors nuts
2004 Excursion 4x4
Old 09-23-2012, 09:51 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
Note that a two prong fuse will fit into the trailer connector directly, happily enough - nothing else needed. A 5 or 10A fuse is perfect.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 09-23-2012, 10:50 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I made a project out of it; I made two different control units. The top one only has an on-off switch and flashes all of my running lights when turned on. The bottom one allows for steady or flashing lights and will allow for running lights, brake lights, or all lights to be on.
ID:	168918   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-23-2012, 10:58 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Originally Posted by ROBERTSUNRUS View Post
Hi, I made a project out of it; <snip>
I guess you did!!! Geez - how super high-tech mucho fancyoso is that!!!
Old 09-24-2012, 03:34 AM   #9
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Very cool!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 10-02-2012, 03:38 PM   #10
mefly2's Avatar
2015 25' FB Eddie Bauer
Very neat!
Old 10-02-2012, 04:13 PM   #11
RoadHungry's Avatar
2004 28' Safari S/O
Tifton , Georgia
Way cool
RoadHungry is offline   Reply With Quote
