Old 11-14-2014, 01:16 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Replacing the Crank-up Winegard with New Omnidirectionl Model
I would like to replace the crank-up Winegard TV antenna that came with my 2014 International 23D. The 2015s come with the Winegard RoadStar Omnidirectional TV/FM Antenna.
Does anyone know what is involved in making the switch?
Name:	Winegard Omnidirectional.png
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 11-14-2014, 01:30 PM   #2
Lily&Me's Avatar
Normal , Illinois
I would suggest calling customer service at Winegard.
We had to replace our antenna once, and they were wonderful to deal with, basically walked Doug thru it over the telephone.
Good luck, and post a picture!
Maggie
Lily&Me is online now   Reply With Quote
Old 11-18-2014, 12:29 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm not sure the Omni directional are all that good. Some with 2015 models are complaining about the reception with this new antenna. You might be better off adding the Winegard UHF enhancer or install the Jack head replacement.
Old 11-18-2014, 02:50 PM   #4
aquinob's Avatar
Portsmouth , Virginia
This was part of my "Phase 2" this last year.
New mount for the thermostat for the AC and the new Jack antenna terminal:
I put a new JACK rotating antenna up on the roof and ran the antenna wire back down through the fridge vent and into the back of this antenna terminal. There is also 12v access that allows power to the base of the antenna to power the signal strength meter.
And the little wing antenna up on the roof. The antenna can rotate about 350 degrees and the signal meter will show the strongest level of signal. This antenna is designed solely for digital signals, analog need not apply. When I first powered up the flatscreen on the antenna it found about 20 channels, many of which I didn't even know existed.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 11-18-2014, 03:43 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Ditto! The only thing I do with Wingard antennas is remove them when I replace them with the Jack units. They are always taking up valuable roof real estate that should otherwise be used for solar panels. That includes the crank-up type, the large 'flying saucer' original Roadstar found on the Interstates and the newer, smaller Roadstar Plus that Airstream started using on the 2015 models.
The Jack will out perform them all!!!
Old 11-18-2014, 08:34 PM   #6
KYAirstream's Avatar
Northeastern , Kentucky
IMG]
When you ran the wire down through the fridge vent, did you simply drill a hole through the back of the vent and seal the hole up around the wire? If do, what did you use to seal it up?
KYAirstream is offline   Reply With Quote
Old 11-20-2014, 07:04 AM   #7
lewster's Avatar
Just wondering......
Do you not have an existing co-ax cable already on the roof?
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-20-2014, 07:08 AM   #8
Nope, no existing coax at all. Great thought though.
Old 11-20-2014, 06:17 PM   #9
lewster's Avatar
Guess they didn't watch much TV in the 70's.........
Old 11-20-2014, 06:25 PM   #10
1986 31' Sovereign
Miami , Florida
For the record digital/analog is simply the manner of signal modulation. Any antenna compatible with the frequency being tuned (VHF/UHF) will receive both equally well.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 11-20-2014, 07:15 PM   #11
Thanks for the info everyone. Lots to think about.
Old 11-20-2014, 08:21 PM   #12
aquinob's Avatar
Went across the roof, up through the bottom of the vent and through the screen and then down. No need to really seal it that way, it doesn't penetrate any new openings. There was no original coax on mine, though there was a connector that went from outside to inside that they must have used for cable hookup to a tv.
Very happy with the performance, you have a dial on the inside that lets you point the antenna and gives you a relative signal strength via LED's.
Old 11-20-2014, 08:43 PM   #13
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I don't know Jack!
I'm Checking these out on the internet. It appears they come in both complete replacement antennas or just the head unit that utilizes the existing crank up mechanism. Is this true? There also seems to be big price variations from one place to another. Any comments on that?
Ken
Old 11-20-2014, 08:53 PM   #14
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I had virtually no luck with my crank up antenna on my 2013 Flying Cloud. I have since purchased a 2015 Cloud but have not had to opportunity to test out the new style antenna. Reading this thread to get reports on it.
TinCan
graysailor is offline   Reply With Quote
Installing new Winegard on 31''79 Excella with power antenna Nehemiah Audio, Video & TV 0 08-21-2010 07:32 AM
What would you do Keep Winegard or new antenna? NashBuff Audio, Video & TV 16 08-04-2010 05:51 AM
Winegard tripod with lotsa built-in stuff? Kistler Our Community 10 09-28-2004 03:37 PM
