Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 11-21-2014, 11:28 AM   #21
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
There's an iPhone app called TV Towers-USA that shows a map of over-air TV stations and their direction in relation to your location. Works well and saves having to search for them by rotating your antenna. Also, shows network affiliations and call letters. This one or others may also be available for other phone brands...I'm not sure.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 11-21-2014, 11:38 AM   #22
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
With the SensarPro meter I'd have to cut another hole in my wall for the coax connector. Too bad they don't have a model that integrates the coax connector.
Old 11-21-2014, 11:38 AM   #23
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Originally Posted by mrprez View Post
Does the channel sensing work OK? That is my biggest issue is trying to aim the antenna. Any wiring changes?
That's the main reason for getting the device.
It works!
2013 25 FC FB (Twin)
2013 Suburban 2500
https://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 11-21-2014, 02:45 PM   #24
aquinob's Avatar
Portsmouth , Virginia
Originally Posted by Ag&Au View Post
The problem is that the amplifier on a omni directional antenna will also amplify any interfering signal and electrical noise coming from any direction.
Ken
Just to clarify, the Jack is not omni-directional, you can rotate it about 359 degrees and watch the picture on the tv as well as the signal strength change.
Ongoing adventures at:
https://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 11-21-2014, 04:16 PM   #25
Ag&Au's Avatar
Port Orchard , Washington
Thanks. I guess I was a bit confused about that. Do the ones that are mounted on what appears to be a rigid pedestal rotate?
Ken
Installing new Winegard on 31''79 Excella with power antenna Nehemiah Audio, Video & TV 0 08-21-2010 07:32 AM
What would you do Keep Winegard or new antenna? NashBuff Audio, Video & TV 16 08-04-2010 05:51 AM
Winegard tripod with lotsa built-in stuff? Kistler Our Community 10 09-28-2004 03:37 PM
