Old 06-02-2016, 12:16 AM   #43
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Talking Garmin RV760 with BC-20.
Originally Posted by Silverbee View Post
Has anyone tried the Garmin for RV with camera? Need a new Garmin so, why not this?
http://www.amazon.com/Garmin-760LMT-...=garmin+for+rv
Originally Posted by nwclassic View Post
65Streamer -- I just asked Garmin about GPS/camera (I have the 2797lmt). They said 2789lmt mates with BC wireless camera (but not mine ) My goal matches yours.
Originally Posted by kacnps View Post
We installed the Garmin RV 760LMT that has wireless backup on our 23' Flying Cloud. The back up camera was installed right above the rear window and works seamlessly with the GPS in the cab. So far it's been great. Not that crazy about their trip planning tool (Base Camp) - not very intuitive...
Originally Posted by AWCHIEF View Post
Realize this an older thread. How did you wire the camera? I do not have a back up light on my 2011 Safari 23 to properly wire it to.
Originally Posted by SeaLevel View Post
I was considering going with the Garmin solution, and while researching it I think some people ran the cable from the camera to the transmitter under the AS, and powered the transmitter off the battery in the front. They used cable ties or something similar wherever they could from to hold the cable in place.
Hi, I have had and used my Garmin RV 760 for about one year so far and really like it. I was hoping to see someone's rear camera install to help me do mine. Well since I couldn't find anything, I just decided to see what I could do. I have been working on it for two days and have been having problems, but I think I finally have it. It will be some time before I can actually take my trailer out for a real test. I made my own camera mounting bracket and my power source is in my left tail light.
ID:	263699   Click image for larger version
ID:	263701   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-02-2016, 05:46 AM   #44
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Your camera mount is similar to mine.
My camera gets power from the tag light.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-24-2017, 06:06 PM   #45
Tom and Phyllis
Lucky Tom's Avatar
2009 23' FB Flying Cloud
Tuscaloosa , Alabama
On backing: The military teaches it this way. Start with the tow vehicle and trailer straight. Use basically one hand to steer while backing. So whichever hand you want to use, place that hand at the bottom of the steering wheel. Now it gets easy, whichever way you need the rear of the trailer to go, just move your hand in that direction as you back up. Start with small amount of steering wheel rotation until you see how much response you get, the length of the TV and AS will determine how much steering you will need. Hope this helps.
Tom, Phyllis, and Snowy, the white Siberian Husky
2009 23ft FB Flying Cloud
2015 Ram 2500 Cummins Turbo Diesel Crew Cab
LD Valley w/ 800 lb trunion bars
Honda eu3000is generator
Lucky Tom is offline   Reply With Quote
Old 01-24-2017, 06:11 PM   #46
Tom and Phyllis
Lucky Tom's Avatar
MaineStreamer, did you install a wired or wireless? Hope you answer wired, I am in search of tips for the wired kind.
Old 01-24-2017, 06:16 PM   #47
Tom and Phyllis
Lucky Tom's Avatar
Artic fox, I also have that same bike rack and I will consider doing that rather than making a hole, my system arrives 27 Jan and it is wired, just one cable travels from the hitch/tongue area I assume, that would power the camera and send the video back up front. May take this one little cable down under the AS from the bike rack attaching it with sheet metal screws to the belly pan. Does anybody think it would work? May try to mount a vertical piece of aluminum tubing to the bike rack to gain some vertical perspective.
Old 01-24-2017, 06:22 PM   #48
Tom and Phyllis
Lucky Tom's Avatar
Go to youtube, I just watched it being done to the rear of a moving van, drilling a hole is drilling a hole. With a typical hole saw you have a pilot bit which makes your starter hole. Just make sure this pilot bit protrudes from the hole saw with a minimum of length.
Old 01-27-2017, 05:54 AM   #49
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Wireless.
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 02-19-2017, 06:47 PM   #50
2017 30' International
Lincolnwood , Illinois
JC will e-mail you instructions for install of voyager
seems simple enough. newer models have a connection you fish out for the hook up
Milo1952 is offline   Reply With Quote
Old 03-09-2017, 07:45 AM   #51
Launce
Launce's Avatar
2012 16' Sport
Greenbelt , Maryland
Camera on Sport 16
Don't know if I should post here, or start a new topic. Anyway ...
I just bought a 2012 Sport 16 and I want to install rear-view cameras.
Right now I'm thinking of a TadiBrothers 7" mirror clip-on wireless monitor, with a license-plate camera on the tow vehicle to help with hitching and general non-towing backing up, and a second wireless camera mounted high up on the trailer. (I'm figuring as long as I'm towing something tall, I might as well take advantage of the height to see over cars behind me.)
Here's my question (I knew there was a question in here somewhere!): To power the camera on the trailer, can I tap into the center clearance lamp on the Airstream? Is there a way to mount the camera without screwing into the skin? If I do screw it down, is there a way to do that which will minimize damage?
I guess I have a second question, having to do with the viewing angle. TadiBrothers seems to use 120° as their default. Does that sound right, or do people prefer something wider or narrower?
Any other comments welcome.
Launce is offline   Reply With Quote
Old 04-02-2017, 07:18 PM   #52
SilverLife's Avatar
2017 22' Sport
Aptos , California
If you haven't chosen a camera system yet, check out my camera review under 2005 and newer Bambi's. I'm very pleased with it.
"If you don’t know what else to do, drink beer."-Wally Byam
SilverLife is offline   Reply With Quote
Rearview camera rp709 Electrical - Systems, Generators, Batteries & Solar 0 03-18-2012 07:16 PM
Successful installation of wireless backup / rearview camera longdog Audio, Video & TV 29 08-22-2011 01:51 PM
installation of rearview camera qt4ca Electronics & Connectivity 3 09-08-2010 04:34 PM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 02:50 PM
Rearview Camera Sysytem moosetags Electrical - Systems, Generators, Batteries & Solar 1 08-21-2006 03:30 PM
