Old 08-20-2015, 05:14 AM   #29
Peterborough , New Hampshire
I have a unmounted Voyager camera. I will try mounting it inside on the rear window and get back to you. Terry
terrylarock is offline   Reply With Quote
Old 08-20-2015, 08:29 AM   #30
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Thanks Terry!
As I mentioned earlier I'm thinking of mounting the camera on the top arm of my bike rack. That would put it about the same height as the bottom of the back window. So if you could give me an idea how the camera prospective is from that angle that would we great
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-20-2015, 10:03 AM   #31
Coast to Coast
Two Peas's Avatar
2016 26' Flying Cloud
St. Augustine , Florida
We installed the Garmin RV 760LMT that has wireless backup on our 23' Flying Cloud. The back up camera was installed right above the rear window and works seamlessly with the GPS in the cab. So far it's been great. Not that crazy about their trip planning tool (Base Camp) - not very intuitive...
Two Peas is offline   Reply With Quote
Old 08-20-2015, 11:25 AM   #32
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by nashrover View Post
I recently saw a wireless back up camera that sends the feed to your iPhone which would be ideal for me. I'll have to go back and find it to post it here.
D
https://www.rvrearviewcamera.com
I use this with my iPhone and it works well.
2012 Dodge Durango Hemi/AWD
Old 08-20-2015, 03:48 PM   #33
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Here is what I use: https://www.rvrearviewcamera.com/
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 08-20-2015, 04:01 PM   #34
2015 25' Flying Cloud
Annapolis , Maryland
I love the iBall camera because it is idiotproof and cheap ($150) and no, I am in no way connected to the company that markets this product. The camera had a magnet that secures to the underside of the AS bumper where the rear storage is. The display plugs into your cigarette lighter and that's it. No wires, no installation! My only complaint is that the display is a little small but you can get used to it. I keep it in my TV until I need it.
iBall - $149.95, Free US & CDN Shipping, Wireless Trailer Hitch Camera – iBallhitchcam.com
Roll-on is offline   Reply With Quote
Old 04-22-2016, 06:23 PM   #35
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Realize this an older thread. How did you wire the camera? I do not have a back up light on my 2011 Safari 23 to properly wire it to.
MICHAEL
Old 04-22-2016, 06:48 PM   #36
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I was considering going with the Garmin solution, and while researching it I think some people ran the cable from the camera to the transmitter under the AS, and powered the transmitter off the battery in the front. They used cable ties or something similar wherever they could from to hold the cable in place.
SeaLevel is offline   Reply With Quote
Old 04-22-2016, 07:01 PM   #37
Mrjkq's Avatar
Venice , Florida
I had the latest Voyager digital wireless installed a couple weeks ago at Camping World & it performs flawlessly, highly recommend the Voyager Camera.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-23-2016, 06:51 AM   #38
Coast to Coast
Two Peas's Avatar
We went to the dealer to installl
Old 04-23-2016, 07:03 AM   #39
AWCHIEF's Avatar
Images: 33
Do you know how they ran the wire and powered the Garmin camera on the 23?
MICHAEL
Old 04-23-2016, 07:58 AM   #40
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I did not want to drill a hole in the end cap, so I mounted on a section of aluminum angle, and attached with double sided tape with small self tamping screw in the window drain channel.
ran the wire down the side of the window and connects to the license plate light wire.
works well for us. certainly mounting on the end cap and running the wire to the center clearance light is a cleaner install, but it does involve drilling holes.
Steamy1 is offline   Reply With Quote
Old 04-24-2016, 03:04 PM   #41
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Wired rear view video camera on a Bambi 19'
Bought this camera from Amazon:
http://www.amazon.com/Rear-View-Safe...+backup+camera
Tried a similar one from Tadibrothers, but after numerous problems sent it back for a refund.
I selected a wired camera because I didn't want to permanently mount the camera near the roof of the AS and had used one on a bumper mount on a previous AS. The camera and mount can be removed for storage. The camera is powered by the car (12V plug which is only powered when the ignition is on). The wires from the camera run under the trailer to the car and generally follow the gas and water lines up the curb side. The connection between the trailer and car is via a "quick disconnect" waterproof connection this is part of the camera/monitor kit.
We mounted the monitor using a cup holder mount:
http://www.amazon.com/ChargerCity%C2...YJDDB5BG9KRCRG
George
Name:	camera mount easily removed.jpg
ID:	261300   Click image for larger version
Name:	camera mounted on bumper.jpg
Name:	camera connected to car.jpg
ID:	261302   Click image for larger version
Name:	cup holder monitor mount.jpg
ghatfield is offline   Reply With Quote
Old 04-24-2016, 10:09 PM   #42
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
George
I installed similar 3'years ago... Reliable... Good product. Cameras are marginal image quality but very robust and great IR illumination... You can't count the wrinkles in the bark of a tree, but you can see when you are about to hit it... Or adjust and miss.. 😎
Peace and Blessings..
Channing
WBCCI# 30676
Rearview camera rp709 Electrical - Systems, Generators, Batteries & Solar 0 03-18-2012 07:16 PM
Successful installation of wireless backup / rearview camera longdog Audio, Video & TV 29 08-22-2011 01:51 PM
installation of rearview camera qt4ca Electronics & Connectivity 3 09-08-2010 04:34 PM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 02:50 PM
Rearview Camera Sysytem moosetags Electrical - Systems, Generators, Batteries & Solar 1 08-21-2006 03:30 PM
