Radio antenna wiring question - 2007 Safari SE 25 SS
Searching for the wire(s) connecting roof top radio antenna to the back of the Sony stereo (upgrade package). It's an incredible rat's nest of wiring behind the Sony CD/Radio box!
I want to splice into the existing radio antenna connection to provide my little portable solar powered AM/FM/Shortwave radio with better reception. We usually dry camp, and don't want to use up battery amps running the factory installed Sony.
I did find a wire coming from the back of the Sony labeled "ANT" (right position and color, based on diagram in Sony manual), but it isn't connected to anything. Can't find a loose end in the rat's nest (so far) that might be the no-longer-attached wire from the antenna.
Anyone know what kind of wire(s) I should be looking for?
Thanks.
