Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 02-15-2009, 08:58 AM   #1
Profile:  2001 30' Excella
Placitas , New Mexico
Problem with Phone Jack
On all phone jacks, once the telephone cord is plugged into the jack, it cannot be released with the jack lever. Have tried prying it out, removing plate cover from the wall and pushing the jack from the rear of the plate; nothing works. Has anyone had a similar problem or can someone suggest a solution short of replacing the entire plate.
geneabq is offline   Reply With Quote
Old 02-15-2009, 09:11 AM   #2
darlingbooks's Avatar
Profile:  2006 34' Classic S/O
Parkdale , Oregon
Images: 51
Most likely the plug on the end of the cord has a sharp edge on the plastic wing-spring catch. Sometimes a pair of pliers on the plug would be necessary for removal, being sure to press on the wing-spring catch, and maybe the help of a small (eyeglass type) screwdriver. Try another cord when you get it out, this will let you know if it is the plug on the cord or the jack.
Lot of luck
Steve
darlingbooks is offline   Reply With Quote
Old 02-15-2009, 09:12 AM   #3
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, Welcome to the Forums. We're glad to have you with us.
I have had same problem from time to time with both telephone and cat 5 locking plugs. I have always been able to remove them using a small pocket knife tip to further depress the locking tab.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 02-15-2009, 09:50 AM   #4
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
after holding in the release tab, try pushing in the plug before pulling it out.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Electrical jack problem mjdsquad Batteries, Univolts, Converters & Inverters 3 01-16-2009 11:26 PM
jack post problem tomcook Jacks, Stabilizers, Lifting and Leveling 13 06-21-2007 10:07 PM
Power Jack Problem muvywrtr Jacks, Stabilizers, Lifting and Leveling 23 04-01-2005 05:29 PM
Phone Jack is Wack! 16CCD 2004 MaShep 1999 - 2004 Bambi 17 12-04-2004 10:31 PM
Outdoor speakers/phone jack connection... crazylev Electrical - Systems, Generators, Batteries & Solar 23 08-26-2004 05:22 PM
