Old 09-05-2014, 02:58 PM   #1
1991 29' Excella
Rockwood , Ontario
Problem With HD Jack Antenna
Hi Everyone,
Sat down to watch our tv, pressed the button on the switch for the antenna.
There is a green light on for the switch, but on the HD Jack Antenna on the ceiling there are no lights at all. There is also no picture, no signal on the tv.
Any ideas, and how to check out what the problem could be?
Cheers
breezyway is offline   Reply With Quote
Old 09-05-2014, 05:07 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Did you scan for air channels?
Old 09-05-2014, 06:29 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If a new problem a wire must have come disconnected somewhere, or the circuit in the wall or the Jack that puts power or takes it off the coax has failed. Pull the wall plate and disconnect the wire to the antenna. Make sure the center conductor is about even with the nut part of the connector that screws onto the socket. Do the same at the antenna.
If wire ok, must be the antenna or the wall plate. If you have a voltmeter, check between the center and outside of the connector on the cable at the antenna. You should see 12 volts there.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-05-2014, 06:31 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Did you ever have power to the antenna where the directional dial is located? If so, I would check if you still have power coming in to that point (if you suddenly don't have lights there).
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-06-2014, 06:47 AM   #5
1991 29' Excella
Rockwood , Ontario
HD Jack Antenna
Thanks for all your help
I did have power to the directional thingy, but after bringing it into the AS dealer for a lighting problem near the AC unit, and the rear lighting in the rear bedroom, I only just discovered no power to the directional unit.
How do I check it with the voltmeter, and what could the problem be?
Old 09-06-2014, 07:23 AM   #6
r carl's Avatar
Lin , Ne
I think I would have a chat with the AS dealer.
Old 09-06-2014, 07:54 AM   #7
I'm with r Carl. It was working when taken to the dealer and not working when it came back. They either disconnected something and forgot to put it back or cut a cable.
To check it yourself you will have to get access to the wiring area under the trim piece where the LEDs are at the base of the antenna. Check your manual or download one. The power comes up the coax cable. See my post above.
Al
S/OS #004
Old 09-06-2014, 10:11 AM   #8
Becky B.'s Avatar
1964 17' Bambi II
I'm with Carl too. They messed with something...
Becky
1964 Bambi II
1988 Avion 32S
JACK Digital HDTV Antenna Bigdaddy_2 Electronics & Connectivity 7 03-13-2014 01:48 AM
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
Jack for TV antenna outlet?? Help !!!! goldenlily Audio, Video & TV 4 10-03-2010 07:02 PM
antenna/cable jack lahrfarm Audio, Video & TV 2 02-12-2010 12:50 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
