Old 08-26-2015, 08:03 PM   #1
Hogfan's Avatar
2015 27' FB International
Dallas , Texas
Please HELP this tech challenged newbie
Stupid question alert from non-tech saavy newbie
We just purchased a DISH tailgater. If we plug the cord from the satellite dome into the satellite port on the exterior of the AS, then where do we need to plug the receiver box inside the AS in order to make it play on the TV's inside without running the cord through a window?
In full disclosure we are not currently in our AS, if we were perhaps I wouldn't have to ask stupid questions...ha
Appreciate your insight!!
Hogfan is offline   Reply With Quote
Old 08-26-2015, 08:15 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My 31 classic will be different, but my receiver is in the front overhead cabinet above the DVD player, It is a factory installation....
Old 09-10-2015, 02:12 PM   #3
David Logue's Avatar
allen , Texas
Gooooo Hogs, Soowie.
David Logue is offline   Reply With Quote
Old 09-10-2015, 02:50 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Doesn't the owner manual show this?
There may be a short piece of coax that you disconnect from a plate. Disconnect the coax and from the input side connect to the satellite receiver. The receiver then connects to the TV via probably an HDMI cable that exists in the Airstream that goes to the TV or a HDMI spliter box. If you are mounting the receiver away from the audio/video equipment then that complicates the hookup.
Kelvin
Old 10-11-2015, 08:29 PM   #5
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
Hogfan, did you figure this out? Just saw this thread and we use the same setup. Have to pull the Sat coax from behind the DVD player. (Remove the box the DVD is in and search for coax there) Once found I put the receiver on top of the DVD. Added a 2x4 HDMI splitter so I could have all lines running into the splitter allowing me to watch different inputs on different TV's. Hope all is well.
Chuck
silverlabs is offline   Reply With Quote
Help for vertically challenged mybyebye On The Road... 14 08-03-2011 08:53 AM
Help for the Inverter Challenged! MTsafari Batteries, Univolts, Converters & Inverters 3 03-29-2010 09:22 AM
Some Tech Help Please! lewster Forum Admin, News and Member Account Info 24 01-23-2008 10:47 PM
electically challenged 61Overlander Electrical - Systems, Generators, Batteries & Solar 16 08-26-2003 02:18 PM
