Old 03-24-2014, 12:48 PM   #1
2015 30' Flying Cloud
2016 30' Classic
Covington , Louisiana
Pioneer radio---no AM/FM reception.
I recently and very happily took delivery a new 2014 airstream 30 ft. Flying Cloud. I'm having a problem with the Pioneer radio. Simply put, I have no AM/FM reception. I've made certain the Local/Distance switch is in the off position(and tried all other positions as well) and the radio is otherwise properly set up. I've also made certain that the roof top antenna is securely in place. In order to determine if the antenna was properly connected to the radio, I attempted to remove the radio from it's housing. I successfully removed the faceplate but cannot seem to figure out how to remove the radio trim ring. I believe this is necessary in order to use the supplied keys to remove the radio and check the connections. I really hate to tow the Stream back to the dealer but will do so if necessary. I know the Pioneer system is new to airstream but was wondering if anyone has had a similar problem or could offer any helpful thoughts. Thanks.
Sjcjr is offline   Reply With Quote
Old 03-24-2014, 01:40 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The trim ring just snaps on, so some gentle prying will be necessary to remove it.
Maybe try bowing it from the top and bottom to determine where the tabs are.
Once one tab is loose the whole trim ring will come right off.
Do other sources work?
You should have AM reception even with the antenna unplugged. The whip antenna is for FM only. The AM antenna is built in.
I wonder if the tuner portion of your stereo isn't working at all.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-24-2014, 02:05 PM   #3
1974 Argosy 20
Kooskia , Idaho
A dealer problem to resolve. Put it on the list with the other things which probably will crop up in the next month or so. Radio reception is not too critical in the global order of things....grin. It can wait a bit.
Old 03-24-2014, 02:09 PM   #4
2016 30' Classic
All other systems function perfectly. It's just the radio tuner that doesn't work.
Old 03-30-2014, 11:38 AM   #5
2016 30' Classic
I have pulled the head unit and checked all connections. Everything seems fine. I still have no AM and very limited FM radio reception. I talked to a friend who also owns a new airstream and is having the same problem with his pioneer radio. Before going back to the dealer for warranty repair I'm wondering if anyone has other trouble shooting suggestions. Thx.
Old 03-30-2014, 04:26 PM   #6
m.hony's Avatar
2013 30' Classic
Seems like the tuner just doesn't work.
Apparently the switch to Pioneer was in the 2014 model year. My 2013 has a Sony, and it works great.
TAC #MS-10
Airforums #70955
Hack a vintage radio antenna for wifi? NJtoNC Computers, Internet & Satellite 4 03-16-2014 07:25 PM
Clipper, Land Yacht, Radio TV Speakers masseyfarm Audio, Video & TV 2 06-23-2013 10:49 PM
Radio upgrade Flynavy Audio, Video & TV 21 03-28-2012 10:21 AM
AM/FM Radio StreamRollin Electronics & Connectivity 2 01-09-2012 09:53 PM
Replacing Radio - Ground Problems? 68Glbtrotter Audio, Video & TV 2 10-06-2011 11:46 AM
